Question about Brother MFC 8820D All-In-One Laser Printer
Brother 8820D Can you please tell me how do I get a hinge for Brother 8820D. Is it easy to replace by myself? Is there an instrution come with the repair kit? thanks. George at gtlei@cfdpcs.com
    Problem Solver:
  • 6 Answers
I purchased a direct replacement from e_techparts on ebay for under $10 + S&H, very simple replacement, just a few screws.
Posted on Apr 30, 2010
    Problem Solver:
  • 5 Answers
RING THIS NUMBER 85676666
Posted on Nov 26, 2008
MFC 8820D ADF Will Not Feed Document
The ADF in my Brother MFC 8820D will not feed a page through
Feb 23, 2013 | Brother MFC 8820D All-In-One Laser Printer
Maintenance error 7 on a mfc 8820D
Thank you for posting to Fixya.com and it is my pleasure to guide you.
I have scanned through the appropriate sections of the
Brother MFC-8820D User Manual & Brother MFC-8820D SERVICE MANUAL
and find no referance to a "maintenance error 7". Please include any and all messages given on the panel LCD!
Please press the reply button and I will check back tomarrow.
It is always a pleasure to help!
Jun 15, 2011 | Brother MFC-8820D Laser Flatbel...
Can't close doc cover properly - seems 'broken' at hinge - can I fix this myself?
The left hinge breaks often enough that Brother changed the part number of the part. I hope that means the new part is stronger; I haven't seen one come back for a second repair. Assuming it's the larger, left hinge that's broken (It always is.), you need an LP2403001 HINGE ASSY L. You can find it from a servicing dealer or online, and it's easy to replace.
Look at the back of the machine and find two large phillips screws in holes. They keep the hinge blocks from coming up all the way out of the machine. Remove both of them and lift the top cover up until it's connected only by its cable. It might take a helper to hold the cover, but you need to unscrew the hinge assy. from the top. The three screws are obvious and easy to reach now that the cover is loose. Put the new hinge on, lower the top back down so the hinges drop into their holes, and put those screws back into the holes in back. You're done.
Jul 11, 2010 | Brother MFC 8820D All-In-One Laser Printer
Left Rear Hinge Assembly Required
This is something you will need to get an authorized service center to repair.
Mar 26, 2010 | Brother MFC 8820D All-In-One Laser Printer
The flatbed lid on my 8820D has a broken hinge in the back. What are sources for the hardware parts so I can repair it myself?
I purchased a direct replacement from e_techparts on ebay for under $10 + S&H, very simple replacement, just a few screws. It's even available on Amazon. Part # LP2403001.
Nov 14, 2009 | Brother MFC 8820D All-In-One Laser Printer
My printer says doc cover open on a mfc 8820d how should i fix.
You have to close the ADF. If the ADF is closed, then the left hinge is probably broken. Look for "MFC-8820D hinge" to find the solution in FixYa.
Jan 10, 2009 | Brother MFC 8820D All-In-One Laser Printer
8820DN hinge problem
To answer Meyerson's questions:
My symptoms did not include papers jamming in the ADF -- in fact, the ADF didn't work at all due to the broken left hinge.  :(  Also, I don't recall having any unusual problems with the ADF jamming frequently before the hinge broke to the point where the ADF didn't work at all.
I obtained the replacement ADF left hinge assembly by searching online for a parts dealer.  I believe I ended up ordering the part from Precision Roller.
I hope this helps,
-Barb
Apr 01, 2008 | Brother MFC 8820D All-In-One Laser Printer
Parts for Brother MFC 8200D
Yes, I had the same problem in Sept 2006 - a broken left hinge that needed fixing. Ordering the part was easy. I was able to install it myself, but it required some attention to detail.
I called Brother International at 800-284-4357, Option 1, then 2. I ordered the left hinge - Part No: LP-2403001 - described as ADF Hinge Assembly (left). If you broke the right hinge, the part number may differ slightly, but person on phone should be able to assist. It cost me $11.55 including shipping.
Feb 28, 2008 | Brother MFC 8820D All-In-One Laser Printer
How to replace broken hinge on ADF on Brother MFC-8820D printer
Look at back of machine and at your new hinge, note the screw hole, if you undo both of those on the back of the printer, entire doc feed will come up and out, BECAREFULL just lift A LITTLE is enough to enable hinge base to be free of sockets (many cables attached) and place doc unit slightly sideways on copy glass to enable yourself access to 3 screws that hold hinge.
Jan 05, 2008 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC 8820D All-In-One Laser Printer Logo
138 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
