SWA Decompressor Xtra from Macromedia,Inc. Need hardware.
Trying to bypass module for wwireless speakers.. Is there a code??
No. If the system came with the wireless rear amp, then it will not work without it.
Jan 18, 2013 | Samsung Wireless Receiver Module Swa-4100...
Samsung swa 4000 need manual and connection problem tips
http://www.samsung.com/us/function/search/espsearchResult.do?input_keyword=SWA-4000&keywords=SWA-4000&b2b=
Nov 21, 2010 | Samsung SWA-4000
Hi I just set up Samsung SWA-4000 and for some reason I cant get it to link up it says Rear Check on the receiver and then the module goes to stand by
This means that its lost the connection to the wireless transmitter, the error means Rear CHK or check hence RCHK. Seems that if the unit is not quite in line of sight the connection can be flaky. I would check the positioning of the reciever. Try moving it, see if you cant get a better connection.
May 18, 2010 | Samsung SWA-4000
Where do i get a user guide from
Your question appears to be about the SWA-4000, I hope that is correct. This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. Here is the manual / guide:
https://a248.e.akamai.net/pix.crutchfield.com/Manuals/305/305SWA4000.PDF
Dec 15, 2009 | Samsung SWA-4000
Can a new tx card be used in a swa-4000
where can you get a tx card from, because i need one and yes it can as long it is for that specific wirless module ?
Jul 09, 2009 | Samsung SWA-4000
Samsung SWA-3000 wireless receiver not linking
This is how I fixed it
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=155394&modelname=HT-BD2&from_osc=
Jan 02, 2009 | Audio Players & Recorders
Just connected the SWA-4000 wireless amplified to my samsung ht-z310 - the readout on the display is "Rear Chk" there is no sound from the rear speakers- any help is appreciated
swa-4000 wireless module isn't compatible with htz310. You need to buy Samsung's swa-3000 to work with your htz310. I had the same problem. It tells you in your owners manual under conectivity where it explains about hooking up a wireless module(pg.55-60). I hope this helps.
Dec 13, 2008 | Samsung SWA-4000
Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
Nov 08, 2008 | Samsung SWA-4000
Problem with wireless conection between Samsung SWA-4000 and Samsung home theatre.
turn the main dvd player off, and press 0,1,3,5 on your remote, then turn on the player and the rear wireless receiver at as close to the same time as you can. should then light up the blue "link" light permanently.
Oct 19, 2008 | Samsung SWA-4000
SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit 2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc. 3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash. 4.) Point the system's remote control at the Head Unit and punch in 0135.  Its light should turn from red to blue. 5.) Perform step 3 again. 6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
Oct 06, 2008 | Samsung SWA-4000
2,218 people viewed this question
 Grubhead
Grubhead
