Question about Refrigerators
I have a powerpoint fridge model trf295. it seems to be still working but not well, the 5 lights for the freezer are all off and super freeze seems to not work and every now and then the alarm goes off so i have held the button in the super freeze light flashes and then you hear a noise like some thing is turning on or off not sure what? this might even turn off the up fridge till i hold it down again confused
  • 4 more comments
  • RORO123 Aug 25, 2008
    I have the same problem with the same fridge, I have tried defrosting but the alarm still sounds every few minutes and the area at the front of the fridge in the middle where the two doors meet has become hot !, did you get this with yours
  • petermcd37 Sep 04, 2008
    The alarm keeps going off at random intervals. Everything seems to be working OK. Peter
  • lornareddin Oct 03, 2008
    I have the sme problem with that model: TRF 295. Alarm light is flashing and the super freeze light goes on an off randomly. Fridge isn't as cold as it should be. Anyone managed to fix theirs yet or know of an engineer?
  • Anonymous Feb 19, 2009
    I have have the same problem but mine is also making weird noises like water bubbling or something. It keeps beeping too and the lights for temperature turn on and off all the time.
  • Anonymous Mar 08, 2009
    Water gurgling noises, fridge section stopped working but freezer area is fine.
  • Anonymous Mar 31, 2009
    i have the same problem
5 Suggested Answers
dcp2
  • 63 Answers
SOURCE: Samsung Refrigerator SR-608EV with water dispenser
There is another sensor in the door that senses how far open the door is. look for this and see if its disconnected or broke
Posted on Jan 28, 2008
SOURCE: I have a hotpoint fridge
I have tried the above solution without success. The only solution to the problem that works is to empty the fridge/freezer switch it off and allow it to do a full defrost. Then switch it on again. This appears to have sorted the problem
Posted on Jun 01, 2008
  • 5 Answers
SOURCE: My Candy fridge freezer CPC240FFK
i recently found out that there is a component in a fidge called a control board this basically tells the fridge what to do i recently had a variety of problems with my candy F/F starting with the interior light not working it turned out to be the CB had this replaced and now working fine i have been told a CB (control board) can pack up from somethng as simple as a light bub blowing so possibly might be your solution all the best
dmb
Posted on Jan 14, 2009
SOURCE: Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Posted on Feb 24, 2009
I have a PowerPoint TRF295 and never took any interest in the temperature settings. I wanted to adjust it but,I don't know which side of the panel is for the fridge and which is for the freezer.Thanks
Hi. Can't make it out in the photo but if they are negative degrees C in the red then your freezer control is on the left.
The ideal temperature setting for a refrigerator is 3?C and for a freezer it's -18?C
Jul 25, 2016 | Refrigerators
LEFT DOOR OPEN OF FREEZER. CLOSE3D DOOR FOR 24 HRS. nOW LIGHTS FLASHING ON SUPER COOL AND SUPER FREEZE.
You will need to unplug and defrost the fridge for a few hours then replug the power. Leaving the doors open allows moisture to freeze on the evaporator while compressor continues to run confusing the control board
APPLIANCE911
Apr 10, 2016 | Hotpoint Combi FFFL1810G Graphite 297 l...
Have a fridge freezer trf295 no model indicated. Need to get my hand on a manual. One problem is that the plug for the fridge is behind it don't know what setting fridge or freezer should be at ???
It looks like it might be a badged Sears Special.
http://www.sears.ca/content/bottom-freezer-fridges
The dials in fridges usually go from zero (defrost) to 9. Ideally you want the setting between 4 and 6. Buy yourself two fridge thermometers, they are cheap. Your freezer needs to be minus 16 - minus 18' Centigrade. Your fridge needs to be 2 - 4'C. The thermometers have a green area showing the range. Here is an example.
Aug 12, 2015 | Refrigerators
I just bought a used (but never installed) wf 1061 (freezer with a wine fridge). the unit and dsidplay lights up as normal...but i don't hear the compressor starting...can it be in demo mode?...
Try this also:
Super freeze 5 seconds set desired temp press super frees briefly again then adjust the wine cooler temp press super freeze again briefly, Next press menu and select normal. Then press menu again. To exit press super freeze again until it no longer blinks.
Kelly
Aug 28, 2011 | Freezers
Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Shafky
Jun 17, 2009 | Candy CPCA240FFK Bottom Freezer...
Same deal, Powerpoint fridge freezer. Alarm light flashing.
how do i defrost a powerpoint freezer and what is the right temperature
Jun 16, 2009 | Freezers
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
FRIDGE COMPARTMENT FREEZING
i had the same problem the sensor starts at the back of the pcb and snakes its way dow the back of the fridge into the freezer conpartment i ordered a new sensor thinking it was a temp sensor but turned out to be a defrost sensor compleat and utter hassel to fit due to the expanding foam i had to eventualy cut the block off that conects to the pcb and then reconecting it once i got the cable through the foam first 2 days seamed to work fine while there was nothing in it as soon as i put food in it again the fridge started to freeze everything again then about a week later it still ices up at the back the fridge but doesnt seam to freeze the food so much now so still unsure about it all
btw it was the exact same model and before i changed the sensor the light and the super light used to flash on and off
Dec 02, 2008 | Hoover HCA390FFK Bottom Freezer...
Oct 19, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Need help
With this model it suffers with the evaporator freezing up, try to defrost overnight with the doors open, restart the following day and it should start to work ok within 24hrs. Regards Advisor
Jul 14, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
1,148 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
