Question about Fujitsu Computers & Internet
Fujitsu Lifebook S Series. Screen shut down as normal while not active but failed to recover. Switching off / on screen stays black .. not a thing and no sound when switched on. bode5@optusnet.com.au
    Problem Solver:
  • 20 Answers
Hi there, try removing the battery from the back of it and also take out the RAM (if accessible). Leave it half an hour and then put the RAM and battey back in.
If this doesn't resolve the issue email me chris.best4@ntlworld.com
It may be a faulty switch.
Chris
Posted on Jul 22, 2008
How do i factory reset my fugistu lifebook T4220 with out a cd because my computer does not have the thing to put cd's
Step 1Reboot or turn on your Fujitsu Lifebook and press "F12" when the Fujitsu logo appears.
Step 2 Highlight "Recovery and Utility" using your arrow keys and press "Enter." If this options does not appear, you have to recover directly from the recovery disc. Step 3
Select a new keyboard layout on the first screen that appears, if your preferred keyboard is not already selected. Click "Next." Select "Use recovery tools...," and "Next" on the "Operating System" dialog screen. Enter your password, if your system is configured with one. Step 4
Click "Recovery and Utility" on the "System Recovery Options" screen. Step 5
Click the "Recovery" tab and click "Restoring the Factory Image (only C:\drive)." Follow the on-screen instructions to restore your Fujitsu Lifebook. Some models may require a supplied recovery disc be inserted at this point.
Mar 10, 2015 | Computers & Internet
How to activate touchpad on fujitsu lifebook modela6025 a series
Go the Device Manager under Control Panel and make sure it is not disabled. Right click and select enable. If you see a yellow exclamation mark next to it means the driver has not been installed and you will have to download and install it.
Jul 17, 2014 | Fujitsu LifeBook A6025 Notebook
My fujitsu lifebook s6010 will not start in normal mode after system restore
Run the Check Disk Utility
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Jun 10, 2012 | Fujitsu LIFEBOOK S6010 Notebook
Black screen when turned on
first thing you do is to change the RAM (memory). if still black screen, you have to re-install or format again the laptop.
Aug 15, 2009 | Fujitsu LifeBook A3130 PC Notebook
Fujitsu Siemens Black Screen problem
Hold the power button in for a few seconds, until it powers off. When it reboots, change your power settings. Don't shut the monitor off after any time span, it isn't necessary.
Aug 08, 2009 | Fujitsu Siemens LifeBook T1010 Tablet PC
Display problem in Fujitsu LifeBook C Series(c-6631
the internal bulbs of ur monitor screen have deteriorated...the manufacturers are real smart, these monitors dont last forever. So if repair estimate is too expensive then replace the whole unit.
Always purchase laptop or notebooks NEW or never more than 5 years old.
May 24, 2009 | Fujitsu LifeBook C6631 Notebook
I have a fujitsu C series lifebook and my display is black when i turn it on everything else works and if i hold it up to a light i can see the screen as it should appear
It's problem of the LCD converter, it's easy to replace. Take out the four screws at the corners of your screen (they are covered by rubber footing or a sticker), carefully take off the bezel, you should see a 6 inches long some sort of circuit board just above the keyboard, at the bottom of your screen. That's the inverter, check the model number and search for it on eBay, it's usually about $15 to $30 bucks. Replace it, and everything should back to normal.
Apr 08, 2009 | Fujitsu Lifebook C1020 Notebook
Computers & Internet Logo
129 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
