Question about Refrigerators
Fridge model c373 is rattling. Has been repaired twice to no avail.Sounds like bottles rattling but have removed all items from fridge. Was sent away for repair and when given back had a rattle.
  • 1 more comment
  • davmarl100 Jul 22, 2008
    It sounds like bottles rattling together,but i have emptied the fridge so its not anything in the fridge bumping tgether. It also sounds like the glass shelves are loose but have checked that as well.thanks
  • sdobbins Sep 06, 2008
    Sounded like the fan was hitting something or grinding off but after 3 days it has stopped and the back of the fridge is icing up but the rest of the fridge is not cold, so it looks like the fan has stopped working altogether and now is no longer distributing cold air around the fridge cavity.Fridge is only 3 years old and we paid $1045 for it. It had a 2 year warranty.Looks like we've been ripped off if it's unfixable and even if it is it's lousy.
  • robert samples May 11, 2010
    is it a tinkling kind of rattle or a poping or gurgling is is a top moent or a sxs
  • 1,314 Answers
There are two things that come to mind from what you are describing one is the evaporator fan is mialignet and hitting its caseing in the freezer or the condenser fan behind the unit where the compressor is is doing the same thing pull the unit out and check it first as its metal and would give a closer sound as your describing
Posted on Jul 22, 2008
Dirty water lying in white tray above black gas bottle at back of fridge
This is probably dusty dirty water that has condensed on the black frame work (or back panel of the fridge) that removes the heat from the fridge. Its normal but try moving the fridge 1inch further away from the wall to help air circulation.
Dec 28, 2015 | Refrigerators
Maytag RSWE0C making noises and fridge freezing food
follow this steps and fix it. God bless you
  1. Internal compressor problemThe compressor moves the coolant through the unit, and the fan moves the air. Both have spinning motors that need lubricant to remain in good working order. When these items begin to fail, if they don't shut down completely, you will hear the high-pitched noise of metal rubbing against metal. One solution is to level or balance the "adjustable feet" of your appliance to promote even distributions.
  2. Evaporator fan defectiveIf your fan no longer operates correctly you must fix the loose fan to prevent the sound from occurring. Make sure you let it defrost and then repair/replace.
  3. Defrost water pan rattlesIf the pan rattles when it is replaced, this is an indication that it is being placed too close to the compressor. Solve this pr
Nov 14, 2013 | Maytag MSD2756G Side by Side Refrigerator
Putrid smell from fridge
add one bottle of vanilla extract (real not imitation) to a spray bottle of hot water remove all things from fridge and spray it down twice the hotter the water the better
Feb 12, 2012 | Bosch Freezers
My C373 Fridge only should be frost free but it keeps Freezing up and then doesnt keep anything cold anymore
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Jan 04, 2011 | Fisher and Paykel Refrigerators
The lowest section of one of the 'legs' of my Linhof tripod suddenly fell out. I retrieved the clip, rectangular black plastic piece and a flat 'silver' piece and that is all. Cannot replace the section...
Linhof photographic equipment is sturdy and robust, designed for use by busy professionals. I cannot understand how you can break this item not once but twice. Take it to your local repair facility and get them to repair it for you.
May 05, 2017 | Linhof Photography
My refrigerator has a loud rattle in back when the compressor (i think) shuts off. when i pulled fridge away from wall i can simulate the noise by shaking what looks like an expansion tank. Sounds like a...
more than likely you probably have a bad compressor foot mount . It is a rubber cushion between the compressor and the refrigerator base frame. they wear out, allowing the compressor foot to contact the mounting base which would be metal to metal contract.
Mar 13, 2010 | Refrigerators
Whirlpool Fridge Making a rattling noise
There are 2 areas it could be in....The upper area where the evaporator fan is....or the lower area where the condenser fan is..
If it is in the freezer...when you open the door there should be a button that the door connects with that you can hold in manually to make the fan engage..and listen for the noise..the odds are if it were ice build up....your thumping the fridge would not make it stop ..since the thumping would not remove the would continue to build up and the fan would eventually stop completely and everything would warm up. It could be a loose stap that holds evaporator lines in place or a motor mount that is loose ..
Or it could have to do with the condenser fan..where the compressor is.The compressor and condenser coil are located underneath the freezer section of your refrigerator. There is some tubing connecting the compressor to the condenser coil. There is also a condenser fan to cool the condenser. To access these parts the refrigerator has to be pulled away from the wall. If you pull the refrigerator out go slowly and watch the tubing that connects from the water valve on the back of the refrigerator to the water cut off at the wall.
Remove the power from the refrigerator. Remove the lower panel on the rear of the refrigerator. Look inside for anything loose. Locate the condenser fan motor and blade. These are the areas to stay away from when power is applied. Plug the refrigerator back in being careful to avoid the condenser fan motor and blade. Wear gloves to prevent burning yourself on the hot refrigerant lines and try touching tubing and lightly pushing and pulling to see if you can cause or stop the noise.
Generally a rattle or hum is caused by a refrigerant line touching part of the cabinet or base pan. If it is not repaired it may rub a hole in the refrigerant line causing the refrigerant to leak out. If you don't feel comfortable trying to correct it, you should schedule service and let a technician repair the refrigerator.
I hope this helps...please rate me ...thanks The Fang
Mar 26, 2009 | Refrigerators
We have a relatively new Bosch fridge-freezer. It has started chuntering away like a motor-bike in the corner of the room. It flls silent if either door is opened. Sometimes it falls quiet and runs sweetly...
Hello mathsmike,
Welcome to fixya,
You said,We have a relatively new Bosch fridge-freezer. It has started chuntering away like a motor-bike in the corner of the room. It falls silent if either door is opened. Sometimes it falls quiet and runs sweetly for hours before starting this racket again. Any ideas?
What is the Complete model number and the date you bought the fridge!
It sounds like it may be a faulty fan or fan clutch from here, if it's not something else very simple!
Send me the info requested and do a repair search for you !
Waiting for your response!
Here are some common noise problems till I look your unit up
1.Check that the fridge is level, using a spirit level!
2. Appliance is touching some other unit or appliances, or counter or wall.
3. Drawers, baskets,or storage ares are loose, or sticking!
4.Receptacles or bottles are touching. Move them away from each other,
ESPECIALLY ON THE DOOR,because it's quiet when the doors are open!
Oct 21, 2008 | Bosch Refrigerators
Looking for a frs22zrf service manual (frigidaire/electrolux). fridge is still running but is not staying cold. Freezer seems ok, but is not as cold as it should be. Side by side unit. Would like to try to...
Hi there!
You should be able to identify various parts Here
It sounds like a problem with defrost timer control, but may also be the control board for the thermostats.
Just click the link , put in Electrolux, fridges, then electronic parts in the box at the bottom.
(shop around before you buy, and try removing/ testing items before purchase)
Jun 28, 2008 | Electrolux Refrigerators
Refrigerators Logo
205 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
