Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Screen is black with a wierd splintered color
I was tossing the remote to my family when it accidently bounced off him and hit the very far left of the screen. The screen went black and there looks like a splattering of shattered color but to feel the screen it is still smooth. It is a SONY Bravia. My daughter is very ill and we were just about to sell it to help her. Can you tell me what to do
  • gjfmaf Oct 09, 2008
    I have a 2 year old Bravia model KDL 40S20L. It began to exhibit problems last week delaying the switch from channel to channel. Now it has a black screen.. After 30 seconds a band of colored dots appears along bottom of screen and, sometimes, 4 vertical lines - orange, green, blue, rose - flash on and off on right side of screen. What is wrong?.
  • 4,234 Answers
Unfortunately it sounds like you cracked the LCD panel. This can not be repaired other than changing the panel itself. I don't have a listing for the KDL-40S2000, but similar 40" sets have replacement panels that run in the $2400 range.
Dan
Posted on Jul 22, 2008
Tip
TOSHIBA DVD REGION FREE HACK METHOD.
1. Power on.
2. Open tray.
3. Push the info on remote once (with supplied remote). You will see numbers.
4. Press 9 for multi-region. Keep trying until you see the number 9 appear in upper left corner.
5. Power off.
Power on.
on May 21, 2012 | Toshiba Televison & Video
Tip
How to Remove Scratches in Stainless Steel
Whether you can remove a scratch has much to do with how deep the scratch goes. Here are several ways to deal with this problem and restore your cookware, stainless steel appliances, countertops or sinks to their former glory.
Consider using a product made for stainless steel such as Scratch-B-Gone or Bar Keepers Friend.
Or, try spraying an all-purpose cleaner (such as Formula 409) on the scratches.
Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
Rinse the surface and wipe dry.
You may also use a solution such as WD-40 to help fill in the sctraches and coat the stainless steel on the unit(s).
on Oct 19, 2011 | Frigidaire Refrigerators
Windows driver
.Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;} .Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;}
The entire installation cd here: http://d01.megashares.com/index.php?d01=6b830bb. It‘s an image file that you‘ll have to burn to a cd. You can use a Nero, Imgburn, Roxio, or any program that will burn aniso image to a blank cd. Burn the cd, install the driver, and then start using your webcam!
Apr 03, 2010 | Radio Shack VGA PC Camera Webcam
Toshiba Laptop Screen
ur right the chime did it the screen ddnt crack but the piments in side are all jumbled ... the same happened when a relative got in a car accident... replacing will b needed tho
Jul 28, 2009 | Dell Inspiron 6000 Notebook
Tip
How To Properly Store Vegetables and Food
The first step in proper storage is making sure your refrigerator is at the proper temperature. You will want to make sure your fridge is somewhere between 34 degrees and 40 degrees Fahrenheit. If your fridge goes above 40 degrees, your food will spoil more quickly, but if the temperature is too low, the vegetables in your drawer will freeze.
Often, crisper drawers will have a mechanism to regulate how much moisture flows into and out of the drawer. Depending upon which vegetables you are storing, set the drawer to either let moisture out for drier veggies or keep moisture in for vegetables that need the humidity. Having a fridge with multiple crisper drawers is helpful in storing vegetables based upon their humidity needs.
Vegetables tend to be very sensitive to ethylene, a substance that comes from most fruits and a select number of vegetables. Because of this, storing fruits and vegetables separately is advised. Ethylene exposure is responsible for carrots turning bitter, the yellowing of certain green vegetables and lettuce turning brown. In addition to absorbing ethylene, some vegetables also absorb odors from other veggies. For example, the odor of apples is absorbed by carrots, cabbages and onions. If odor absorption occurs, it can affect the taste of the vegetable. Add a box of baking soda to the crisper drawer to help with odor absorption. After about two weeks, you'll want to shake out the top layer of the baking soda to maximize freshness.
Some vegetables benefit from being stored in a bag in the refrigerator rather than being out of a bag. These vegetables, such as artichokes, broccoli, cauliflower, cabbage and eggplant, should be placed in the crisper bin in perforated plastic or paper bags so that they can maintain moisture. However, some vegetables like lettuce don't do well with lots of moisture; for this reason, you should not wash your vegetables before storing, but before eating instead. With carrots, beets, radishes and parsnips, removing their tops prior to storage will help them keep longer. Similarly, the head of celery stalks should be covered before storing.
Black and white
Unplug the home theater for about 2 minutes, and see if the default color has been reset once you replug it.
Mar 23, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Atari 2600 Jr. left on overnight, next day no color
Flip reset switch, then retry b/w/color selector (or switch from ch. 3 to 4).
Apr 08, 2008 | Atari 2600 Console
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
128 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
