My computer will start up for a couple of seconds, then it will fill the screen with horizontal copies of a small horizontal strip of a piece of the screen. It's a Compaq laptop, product Presario F500.
  • NINT_IT Jul 22, 2008
    I can't get that far. I have other computers to use though, can I do it from one of those computers with a hook up of some sort?
  • 68 Answers
It its a virus infected..all you have to do is to scan the viruses and delete it.
Posted on Jul 22, 2008
I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the seco
Is it prints or copies or both? If it's copies, clean the document feeder glass - small strip. What make/model? Laser? If laser, check the fuser roller
Nov 29, 2014 | Office Equipment & Supplies
Vertical strip of flashing horizontal lines on Acer Aspire 7551G screen
More than likely it's the lcd screen and will have to be replaced. I could be the video card, but most likely the lcd screen especially when you can put pressure on the screen and cause changes. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok, then the problem is with your lcd screen and the video card is ok. If the Borrowed monitor displays the same as your lcd screen then the problem is with your video card inside the computer.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Once you narrow it down to the lcd screen as being the problem you might try taking the lcd screen apart to reseat the lcd cable on the back at the top of the lcd. Just unplug it and plug it back into the connector. You can also try doing the same where the lcd cable plugs into the motherboard. Just pull it out and put it back.
May 31, 2012 | Computers & Internet
I just put the cartridge in and it won't reset. I can't scan, print, or copy. It keeps flashing the screen: "put in cartridge". I took the cartridge holder out and cleaned it off, but to no...
Your probably experiencing a fairly common problem that's easily fixed. Most ink cartridges are shipped with a small plastic strip (like adhesive tape), taped over the nozzles and metal contacts. These thin strips have a tendency to tear when being removed, leaving a small piece that interferes with printer recognizing the cartridge. Remove the cartridge and examine the bottom very carefully and remove any remaining tape.
Feb 27, 2011 | Canon PIXMA MP130 All-In-One InkJet...
White strip on copy
While you make an printout, open cover when the paper is approx. in drum section.Remove drum, and you will see the picture on it, if the piece of picture missing, that is your white strip. On the drum you will see two blue small handles with markings pull. Dismantle it with help of this handle and you will be able to see the developer unit ( magnetic roller cover with toner ). If the white stripe also on it change developing unit, and drum unit.
Jun 22, 2010 | Canon ImageRUNNER 1670F Copier
Horizontal streak
Clean the scanner strip glass. This is the small strip of glass that is just to the left of the large main glass. This is the only cause for black line (s) when copying using the ADF(top feed). If prints or copies fine from the glass then it is this strip glass needing to be cleaned.
May 04, 2010 | Ricoh Aficio 450 Copier
Large black horizontal stripe on copies from Canon ImageClass D760. Recently had ADF and rollers changed.
Sir,
If you place and orginal on the large glass and may a copy does the strip dissapear? If not it could be cleaning blade drum fuser unit? If the strip does leave then you have a problem with the docfeeder glass small long glass next to the big glass. Clean it!
Feb 26, 2010 | Canon Office Equipment & Supplies
Chnaged screen
The PSP shouldn't require soldering to replace the screen. That tab should fit into a slot.
http://www.llamma.com/PSP/images/repair/LCD/111805%20106.jpg
Dec 28, 2008 | Sony PlayStation Portable (PSP) Console
Emerson tv model no. ewf2704
Hi: When you say small horizontal screen, ¿Do you mean picture does not fill the screen completely from top to button? ¿Do images display normally though they are smaller in size? ¿Is color and definition of signal OK? Please answer so I can have a better picture of the problem.
Sep 19, 2007 | Emerson EWF2704 TV
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
Computers & Internet Logo
43 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
