Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
ERROR CODE 39
MY UJ-851S STOPPED RECOGNIZING ANY TYPE OF DISK. I GET AN ERROR CODE OF 39. THE DRIVE IS NOT DISPLAYED UNDER MY COMPUTER. I UNINSTALLED THE DRIVER AND RESTARTED THE COMPUTER. THE DRIVE REAPPEARS UNDER THE DEVICE MANAGER, BUT WITH THE ERROR CODE 39, AND NOT UNDER MY COMP. MY COMPUTER IS AN HP dv6000 WINDOWS VISTA HOME PREMIUM.
  • yehiamohamed Sep 26, 2008
    ERROR CODE 39 problem
  • Jaison Chacko May 11, 2010
    I have 0 chance to change dvd region.so can u help to reset this value.
    (MATSHITA DVD-RAM UJ-851S ATA Device)
    thanks.
    Guru:
  • 111 Answers
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Posted on Apr 01, 2010
My toshiba a215-s4807 satellite, with windows vista won't boot with my mat uj-851s cdrom drive hooked up. I had the same problem with my older version, the mat uj-850s but just figured it was brok
You can change the boot up order of devices in the BIOS. Go into the BIOS setup then to Boot up order and move the CD/DVD dirve as the first boot device and the hard drive as the 2nd boot device.
Then you boot up with a disc in the CD/DVD drive.
May 01, 2012 | Computers & Internet
My HP Pavillion dv6560oe can not install the driver for the MATSHITA DVD-RAM UJ-851s ATA device. The device has stopped functionning (code.10)
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Apr 26, 2011 | HP Computers & Internet
I have not a driver for matshita uj 850 d. the pc not recognised the cd/dvd. thank you.
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Mar 19, 2011 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Matshita dvd-ram uj-851s ata device vista
Foolw the guide below, this will edit the registry, making the device visible and useful again.....
Windows Vista
1. Click Start
and then click All Programs.
2. Click Accessories, and then click Run.
3. Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
4. In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5.
6. In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
7. On the Edit menu, click Delete.
8. When you are prompted to confirm the deletion, click Yes.
9. In the right pane, click LowerFilters.
10. On the Edit menu, click Delete.
11. When you are prompted to confirm the deletion, click Yes.
12. Exit Registry Editor.
13. Restart the computer.
Oct 16, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
My Matshita UJ-840D DVD/CD-ROM Drive Stopped working
i,m assuming this is A laptop Computer ?
The only thing you can try is this:-
go to My Computer/Control Panel/ System/Device Manager.
see if there are any yellow triangles or exclamation marks by your problem device. if so click un-install. then at the top of that page, there is a refresh icon or similar. which will rescan the systems bus.
failing this try add new hardware wizard, in control panel.
finally ensure the device is connected correctly, unlock/remove and re-insert. update any device drivers for this.
Mike @ Compurepair.
Sep 04, 2009 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Cant burn cd - error 4450
So first off, you have a problem with your registry. This is a problem seeing as you are not an administrator and the only way to fix the registry is to be an admin. So if and/or when you are and administrator simply download the RegCure registry repair tool. also get a SpyWare scan as well and update all your system drivers. That should do the trick or just any old program off the internet that cleans out your registry really. If you want to edit the registry manually just hit start>run and type in regedit and mess with it there. unless you know what you're doing i wouldn't recommend messing with the registry though.
Jun 14, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Cannot burn CD or DVD
In the Device Manager, right-click on the DVD drive and select the Uninstall option. Reboot the computer so it will re-detect the drive, reinstall the proper drivers and reset its configuration information. Then try burning the disc again.
Apr 09, 2009 | HP Pavilion dv6326us Laptop
Matshita DVD-RAM UJ-851S
here's the fix
http://msbin.com/kb/entry/53/
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
4. On the File menu, click Export.
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
Note If this data type is missing, go to Method 2.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit Registry Editor, and then restart the computer.
Dec 24, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Does not reccognize dvd/cd drive
go to control panel, classic view, system, hardware, device manager, dvd, cdrom devices and go to the cddrive in the drop down menu and uninstall it. restart your computer and it will reinstall the cd drive if you have any more questions, please email me at meanness628@aim.com
Jun 22, 2008 | HP Pavilion dv9000z Notebook
Write Error
That's almost an adequate error description! It is odd that a 24x CD speed description is given for burning in a DVD-RAM; what media and session types did you pick? If there is nothing (hair, fingerprints, soap...) on the particular disk preventing a burn, perhaps something has a write lock on dlgbrnst.cpp so it can't be reeled off to DVD-RW?
May 30, 2008 | Computers & Internet
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
144 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
