Assuming she ran good before she sat, replacing the plugs, cap and rotor isn't a bad idea.Step 1: Make sure you have good spark. No need to worry about timing right now. Step 2: If you have spark, then we have to see if its getting gas. There are two fuel pumps on this Bronco. One in tank and one on the frame rail. Can you hear either one running? The in tank one should come on for a few minutes and shut off. The front one is harder to hear.If you hear it, borrow or rent a FUEL PRESSURE GAUGE and check your fuel pressure. There is a fitting similar to a tire valve on fuel rail. Pressure should remain constant.If either pump fails you will not get adequate fuel flow. The front pump is easy to get to for trouble-shooting. Don't buy anything unless your sure you will need it. Hope this helps.
