Question about Sansui COM3101 13" TV/VCR
Need to find a code to work the tv/vcr combo from a comcast digital remote
My father in law has a sansui 13 inch tv/vcr combo. his comcast service provider cannot find a code to work his all on button for his remote or even turn the tv on and off. I tried all the codes they gave me but none of them seemed to work. Is there a code that Is out there I havent tried yet. I will get the model number if that will help. please contact me at jfarrin@yahoo.com
  • 1 more comment
  • gailish Sep 01, 2008
    I just bought one used and the remote does not work.  I bought a universal remote but can't get it to work.  Cannot access the menu either.  Any suggestions?
    Thanks,
    Gail
  • Anonymous Oct 19, 2008
    I need the 3 digit code to program my dish network dvr remote to control my Sansui 13 inch tv/vcr
  • latishaboyd8 Dec 07, 2008
    i need programing code for a rca rcu300wbl universal remote to work the sansui com3103 tv/vcr combo.
  • Sansui Master
  • 520 Answers
Try the codes for Orion, Emerson and RCA as well as Sansui. Good Luck!
Posted on Oct 29, 2008
I need the manufacturer's code for SANSUI Model COM3101A in order to program my Comcast remote.
The remote control that you use for your Comcast box will not operate all functions of the TV sice its a combo model. Your best bet is to purchase a universal remote control from the following website. There are 3 different versions of your TV's model number so make sure you choose the correct one for proper operation. Good luck
http://www.remotes.com/remotes/servlet/rs?a=Display&contents=home&uuid=13116091656740
Jul 25, 2011 | Sansui COM3101 13" TV/VCR
Code for universal sony remote sony-v201
Hello
Sorry to say that Sansui is not listed to Sony V201 remote control. Anyway I'll give you some three digit and four diit conds for Sansui. I'm not sure will it work, but try these, sometimes you may get.
Three digit universal remote codes for Sansui are:
135/ 136
Four digit universal remote code for Sansui TV/VCR combo is
0310
Four digit universal remote code for Sansui TV are:
0135 0310
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your combo with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
Hopes you will be helped.
OK.
Jan 27, 2011 | Sansui COM312AD 13" TV/VCR Combo
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Apr 25, 2010 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Remote Code for Comcast DVR
See http://www.comcast.com/corporate/customers/customer_support/remotes.html
You will most likely have to use a VCR code and program it to the AUX button.
Feb 26, 2010 | Panasonic PV-C2541 25 in. TV/VCR Combo
I need a remote for my 13 inch television with a VCR. I have not been able to get a code for a universal remote that will turn it on an off. Help please. Marilyn Powell Model # Como961 A Manfactured June...
Hello, this should be the correct model number of the remote: 07660CG020
Here is an ebay auction for one:
http://cgi.ebay.com/07660CG020-REMOTE-CONTROL-for-TV-VCR-Combo_W0QQitemZ120378205047QQcmdZViewItemQQptZLH_DefaultDomain_0
Mar 06, 2009 | Sansui COM3101 13" TV/VCR
Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
Sep 28, 2008 | Sansui COM3101 13" TV/VCR
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Jan 20, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
Sansui COM3101 13" TV/VCR Logo
363 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
