Question about Refrigerators
Mains adaptor for waeco cf50 has broken down (240 volt)
  • Anonymous Mar 19, 2014
    TURBO LED flashing, TEMP not adjusting
    Sergeant:
    Champion:
  • 347 Answers
Hello darood325,
If you live in the US, i suggest you to visit this link and then get into contact with Waeco and buy another AC adaotor
http://www.waecousa.com/page.aspx?p=rc
Good luck, and anyother question, let us know
Dahaka
Posted on Jul 22, 2008
    Brigadier General:
  • 6,966 Answers
Have you tried getting in touch with an authorized service center?
Or Waeco Pacific Pty Ltd, 1 John Duncan Court Varsity Lakes QLD 4227 Australia Phone: (07) 5507 6000 Fax: (07) 5507 6001.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 22, 2008
    A way to find closest Authorized Service Center is here.
  • Louie  Role
    An alternative is to get a 12VDC/ 5~8 Amps power supply and run the unit with that. This should be more than enough to power the unit.
Hi I have a Waeco CFX50, only had it for 2 months. 240v no problem, was running on 12v off camper and it stopped after6 hours Using my multimeter I am measuring 13.2 v Any ideas?
  • is that 13 volts with fridge on
  • check the ampage reading on the battery also
  • would think its a warranty question
  • no idea what the 3 stage battery protection means
  • sellers claim
  • Operates on 12/24 volts DC or 240 volts AC
  • 3 stage battery protection
  • 3 year manufacturers warranty
Nov 12, 2016 | Refrigerators
I'm traveling to India where electricity is 240. Do I need to buy a power converter for my Asus laptop?
most laptop power supplies support full range power input. meaning it will accept any normal outlet voltages used anywhere. if you look at the power supply of your laptop it should say vin (voltage in) 100v to 240v 50/60 hz, or close to that if it is.
Nov 01, 2016 | ASUS Computers & Internet
How do I replace the Thermistor (thermostat) in a Waeco CF50 12v/240v refrigerator.
JUST REMOVE THE THERMISTOR AND IF IT HAS A PLASTIC COVERING REMOVE IT, THEN PULL OFF OR OUT THERMISTOR, U WILL HAVE TO CUT IT BUT BE SURE TO LEAVE AS MUCH WIRE AS POSSIBLE LEFT TO SPLICE ONTO AND ATTACHE NEW THERMISTOR TO MOST TECHS WILL ADVISE TO USE HI TEMP SEALANT TO COAT THE CONNECTION AFTERWARDS.
Jan 29, 2015 | Refrigerators
Mains adaptor for Vivitar 283 flash.
http://www.hiviz.com/activities/guidebook/sensor.pdf....perhaps this is a help.. not sure..
Sep 06, 2008 | Vivitar 283 Flash
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
Refrigerators Logo
371 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
