Question about HP LaserJet 4 plus Printer
Printer keep printing same job
Hit print button ad printer spits out the same copy until shut off
  • 138 Answers
Check you menu on the printer to ensure that under copies it says 1. It's easy to hit the keys when in the menu under copies one key minus and you now have 999.
Check the default number of copies at the print driver side (when you hit "file print") to make sure it says 1 also.
Hope that helps you.
Posted on Aug 03, 2008
Why do my c305 keep printing
open all paper tray, go to print button, rest job, select "all" job and confirm. keep doing this untill there is no more print jobs showing on your screen, then go to your PC and set your default printer to this device, printing to this printer using the wrong print driver will do exactly what you just described
Apr 30, 2014 | Ricoh Office Equipment & Supplies
Hp 2840 won't stop printing
power off the printer. removed the network cable only. power on until it display ready. now print a config sheet or menu map. if it print without error then connect the network cable and print config sheet again. wait and observed. if it will start printing garbage then KILL the print jobs queued on the printer. after deleting all print jobs power off and power on printer with network cable connected. I hope that will fix the problem. by the way. was there any error display in the panel display like "49.4C02". etc.
Feb 21, 2013 | HP LaserJet 2840 All-In-One Printer
Every time i hook up the kodak esp9 to the computer it keeps spitting out copies of a picture i made a month ago
The problem with this is that the previous printing jobs are still on queue
To delete the Printing queue try doing the ff:
Double click the Printer Icon under Printers and Faxes then
Delete all the printing queue
Click Start then Run then type print stop spooler
Click Start then Run then type print start spooler
Try hooking the printer again
Hope this will help
Regards
Byron
Aug 21, 2009 | Kodak Office Equipment & Supplies
Mp730 won't print color
Hi you can try this.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you will need to clean out the waste ink it inside the printer all got to be open up to do this.
Ok I have put a MP-Tools in my website for you to try out this tools are for reseting your inks plus it can do much more.
Click on the link to download it.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 23, 2009 | Canon SmartBase MP730 All-In-One InkJet...
Hp 1350v all-in-one printer won't print
if you have a print job stuck go in and hit cancel job. If it stays even after a few min right click "my computer" on your desktop and hit "manage" go to "services and applications" click "services" find the print spooler option and right click it and stop the service. Once stoped right click it again and start it. This should clear anything stuck in print queue trying to delete
Jun 22, 2009 | HP PSC 1350v All-In-One InkJet Printer
Printer prints same material over and over.
Check the print spooler (double-click the printer in the Printers and Faxes folder) see if there are more jobs listed if so cancel them and power the printer off and unplug the power cable and reconnect and power on. Keep the paper pulled from the tray until it stops attempting to print. Also check the printer settings (right-click on the printer in the Printers and Faxes folder and select Properties and then Printing Preferences) to see if the default number of copies is set to anything other than 1.
Nov 18, 2008 | Canon BubbleJet i320 Printer
Brother MFC-8440 will not print or copy
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Oct 15, 2008 | Brother MFC-8440 All-In-One Laser Printer
Printer prints top 1" of page, then just spits out blank pages
If the printer works ok on another PC, it seems quite clear that the problem is definately software (Driver) related. If you haven't done so already, I recommend adding the printer through the Printer\Faxes Add Printer Wizard and pointing it to take the drivers off the install CD (if you have one) rather than installing the printer from the CD Autorun. Just make sure that you've deleted the printer completely from Printers\Faxes and rebooted before each install attempt.
I hope this helps!
Cheers,
Matt Coyote
Feb 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP LaserJet 4 plus Printer Logo
47 people viewed this question
Ben Johnson
