Window air conditioner..
I just bought it and i noticed water in bottom of unit is this normal or should i be taking it back?
  • kittibiach Jul 22, 2008
    thank u so much..i can fix a car but know nothing about little appliances...lol
    President:
  • 1,314 Answers
If the water is in the back its very normal that is humidity that the unit ir removing from your house if its in the front the tilt your ac back so it will drain to the back but water is normal
Posted on Jul 22, 2008
    Scholar:
  • 154 Answers
It is normal there is a small hole for the water to escape just make sure that when you mounted it you tilted it down a small amount at the back so it can drip out
Just bought used portable ac. it blows great cold air then blows warm air for a while then back to cool andcold... is this normal? if not hwo to fix?
Yes it's normal in most cases. There should be a knob to turn so it cycles on more often. If it's not a window unit, & is a free-standing unit, you might have to empty a water pan or tank on it. As condensation collects on the cooling coils, it collects in a container near the bottom. If it's full of water, it will cycle the cooling off until you empty the water container or some of the water in it evaporates.
Jul 08, 2015 | DeLonghi Heating & Cooling
My Window unit A/C has started leaking at the bottom onto my window seal and hard wood floors. I have this A?C for about 5 years and this has never happened before?? Any Sugestions???
Condensation of water on the evaporator coils in the front of an air conditioner is normal. This water collects in a pan where it is evaporated. On a really humid day, you may notice some is dripping off the unit. A properly installed unit will be tipped slightly back to allow any excess water to drip out the back.
Aug 05, 2008 | Heating & Cooling
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
Internal unit is leaking water
Check condensate tubes - they may be blocked and need cleaning. All manufactures recommend having your furnace and air conditioner checked and cleaned on an anual basis. You can clean your condensate tubes yourself - if it is severly blocked you may have to use compressed air to unblock, but first to a combination of bleach and water. Better yet a technician will clean the condensate tubes and well as the rest of the unit so that it's running at its top efficiency
Jan 03, 2011 | Heating & Cooling
I have alot of water that gathers on the bottom of the unit and is overflowing on to the floor. WHAT DO i DO TO CORRECT THIS PROBLEM?
Some water is normal on many newer units, but the drain holes often clog with dirt and then they run too full...find the drain holes and clean then out, also make sure the unit is tilted back in the window a bit...
heatman101
Aug 23, 2010 | LG LWHD2500ER Wall/Window Air Conditioner
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Leak from bottom of window unit
The unit needs to be tilted outware. The outside (back) of the unit must be at least 1/4" per foot lower than the front. If you have 2' sticking out, the back must be at least 1/2" lower than where it sits on the window sill.
Aug 10, 2009 | Maytag NMPEB08F2A Air Conditioner
I just bought a samsung 15k BTU window a/c, I haven't seen any water dripping out of the bottom of the unit. In fact there is absolutely no moisture anywhere. Is this normal. Humidity is low, and it is...
If the humidity is low then the amount of water removed will be low. The AC (I assume is a window unit) May be evaporating it off as soon as its drained outside..
Yes in low temps and humidity it is normal for no moisture to be made in abundance.
This is all assuming the temp is coming down as you direct it to.
Please rate me as high as you can and thank you for using fix ya.
Apr 28, 2009 | Kenmore 75050 Wall/Window Air Conditioner
No water
That water is condensate that is removed from the air. If the humidity is low, you will notice much less water coming from the condensate drain line. I would expect to see some water though.
If the unit doesn't seem to cool as well as it did, then chances are it has a leak and has lost its refrigerant charge.
Sep 18, 2008 | Kenmore 75050 Wall/Window Air Conditioner
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
