Does the fan work on heating or nothing at all?
maybe the relay switch is faulty that switches the fan from cooling to heating and that maybe the clicking noise. It maybe that the relay is trying to switch but can't for some reason possibly a short in the relay. Unless you know electronics and can find the relay and remove it and solder a new one on you may have to have the relay fixed by a pro. It should be easy for you to find the relay if you know where the noise is coming from you can just have someone or yourself if possible switch from one mode to the other until you find the relay thats clicking and then you just need to mark it with a marker and turn off the power to the unit and change the relay with a new one. But most are soldered on not just pluged in.
The fan works perfectly fine, the air condotioning works also but when i switch it to the heating mode it does not work at all including the fan.
Also when its in this mode the lights will dim for a split second and there is a cliking noise which i think comes from the compressor, like its trying to get power or something.
Thank you so much for that mate. I WILL get right on to it and let you know how i go.
Cheers.
