Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
Tape will not eject
All other functions seem fine. but the tape will not eject when i open it
  • BillyM1 Jul 22, 2008
    it plays, rewinds, zooms, focuses, etc. when i open the tape cover (which should eject the tape), nothing happens. no beep. the camera beeps when you turn it on and scroll from tape to edit, etc. is there a way to manually override the automatic eject? i've tried the reset button on the side of the camera. i've tried disconnecting the battery, disconnecting the AC power.
If you open the eject thingy like normal then look for a small white plastic tap. its located right underneath the "start/stop" text you see on the back end of the camera (where the record-button is). You´ll need something like a small screwdriver or similar. Press it and and the tape ejects like normal. Worked for me. Saved me the repair bill :)
Posted on Nov 18, 2008
  • 188 Answers
Can you explain...all other functions ?? you mean you are able to play , rewind and forward the tape and it is not giving any error message doing so. Only if you try to eject the cassette it dose'nt works. Kindly check, normally by default, all the sony camcorders generates a beep every time a function is performed. Does the camera beeps or not when you try to eject the cassette.. ( kindly answer, so that i can further try to help you )
Posted on Jul 22, 2008
  • sanjay sharma Jul 23, 2008
    in normal case, when one opens the tape cover fully it presses a micro switch inside which operates the ejecting mechanism. the switch when pressed gives a beep sound. By the condition of your camera it is not making the beep sound, i.e. there are chances 1) either the switch has broken, or 2) the circuitry controlling the eject mechanism is not workig. In any of the cases you have to show it to a repairer.
Pinch roller stuck in "up" position, eject button won't open door
The very first mistake is to pry a door open. That damages them. You are never to do that. The correct way to get a tape out is to open the unit up and find out why the tape is stuck and then take action to release the door in the normal way- usually it is a loose belt or defective cam motor. As to the Pinch roller there are slide plates and even some pinch rollers had lubrication on them so that may have dried leaving you with a stuck part. The normal order of business is the find out what is stuck and then take action to clean and lubricate the mechanism to return to normal function. The problem with some Pinch Rollers is that there may be a particular spot it needs to be set at. This is true if it has a guide fitted to it. Then you will need either a jig or mirror tape to be able to set it correct again. I can not give any further advice without seeing the unit but this should get you started.
Dec 03, 2012 | Audio Players & Recorders
Stuck video tape
Is the tape protection guard rotated upward (and the tape engaged with the heads)?
Aug 13, 2008 | Emerson EWV403 VHS VCR
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
Tape slots won't open and nothing is functioning.
you need to replace your belts, go to partstore.com, punch in your model number and it will give you the correct belt's that you needed
Jun 06, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
Tape keeps getting ejected
This unit requires the rubber parts to be replaced. The loading sequence is not completing properly. The VCR will eject the tape when the sequence fails as a safety measure to prevent damage to either the VCR or the tape.
Parts cost for this should not be more than $10.
Dan
Feb 03, 2009 | RCA VR639HF VHS VCR
CAMCORDER GR-DVL167EK
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Sep 10, 2007 | Video Cameras
Both tape compartments will not eject. Mod. TC-WR535.
I just got two tapes out of my WR535 this morning. I removed the top cover by taking out the screws on the lower sides. It was obvious that the drive belts were stretched out. This seems to be preventing the doors from opening, as the transport mechanism seems to be in PLAY mode without the belts functioning. WIth the cover off you'll be able to see the mechanism that opens the door. There's a small nylon piece that prevents the mechanism from opening the door. Push it downwards with a small screwdriver and the OPEN button will function. You can now retrieve your tapes. I was just looking online for a service manual to see if it's worth trying to change the belts. Not sure yet. Good luck! Dan
Sep 10, 2007 | Sony CASSETTE DECK Single Dual Cassette...
Tape rack stayed open
I just experienced the same problem, but it took me 10 minutes to get it working again. When you look inside the tape rack, you see on the left side in the middle a little mechanical arm which you can press down for about 1cm when you release it again the rack opens completely Good luck Robert
Jul 21, 2007 | Panasonic NV-GS15 Mini DV Digital...
Do i need a new cam???
You cannot tell if the switch for the eject is broken on the printed circuit boar, or the switch knob may only be internally broke unless you take the camcorder apart. I have seen just the knob break off inside and this know is only a few bucks + the labor, and thats what ia going to cost the most.
Jan 05, 2007 | JVC GRD-350US Mini DV Digital Camcorder
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
555 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
