Question about Coleman Mach III Air Conditioner
Older roof mount RV Colman Air Conditioner on a 1989 Motorhome(class C)
The air unit is bowing warm air. the air does not get cool at all. Is it rechargeable??
Thank you for your help....Louise
  • 154 Answers
It depends how old it is most can be regased but about 15 or so years ago they changed refrigerant gases because the old one was killing the ozone if not that old you should have no problems with regasing it just make sure they check for gas leaks first which is a small amount of dye put in the gas so you can see the leak. Hope this helps
Posted on Jul 22, 2008
Posted on Aug 27, 2008
  • Coleman Master
  • 6,674 Answers
Give model & make, and approximately how old. Has anyone checked unit for any possible electrical problem that may be causing this? Is there something obvious that made you feel cooling unit needs recharge? I've seen these run for 10-15 years, so I'm finding it hard to believe that it needs re-charge.
Posted on Aug 16, 2008
Is it common for a rv rooftop air conditioner to leak water on to the roof? I have a Dometic Duo-Therm unit 579,590,595 series.
All AC units create condensation from the cooling of air (cold/cool air hold less water than warm air), it is worse in areas of humid air like the Midwest for example.
May 12, 2017 | Dometic Heating & Cooling
How do I fix the drain lines from my rv roof?
have to remove cover to access drain lines to clear
Jun 10, 2014 | Coleman Mach III Air Conditioner
How to set dometic rv air conditioner control
Cleaning the condenser and evaporator annually will make a huge difference in the cooling ability of the motorhome or camper trailer RV unit. Lubricating the A/C fan motor may help extend the life and performance of the unit itself.
May 14, 2013 | Dometic Rooftop RV Air Conditioner
Where does the 12 volt dc power for the roof a/c come from
comes from your 12 volt battery that is installed in your RV/ Motorhome, which also runs some of your lights in the RV/Motorhome too.
Jun 19, 2010 | Dometic Rooftop RV Air Conditioner
The upper unit doesn't matter ( the actual ac unit on roof ) it's the lower control unit (inside at ceiling) that you need to change to use either ducted or non-ducted system. Any RV dealer can supply that, probably have it on the shelf. Just make sure you write down the model number and serial number, off the bottom of the upper unit, so they can match lower unit to it, for ducted system.
Apr 14, 2010 | Dometic Rooftop RV Air Conditioner
On my 28 foot Itasca motorhome the air conditioner is leaking water through the gasket on the roof. I pulled the inside cover off and took out the four big boltd holding the roof top section, but I can't...
You need to find where the drain is. The water should flow to a drain and not into the unit. Once you get the condensation draining properly you can use a good quality silicone to seat around the unit. You might check at a RV parts place and find a product they recommend for RV roofs. Hope this helps.
Nov 19, 2009 | Dometic Rooftop RV Air Conditioner
I bought an older camper with a colman roof unit ac. My question is do I need to put small filters under the intake grates inside the camper below the ac cover. There is nothing in there. (bought it this...
its good to put them in, as it will keep dust from building up on the coils, thus reducing cooling.just buy some filter material at any hardware store, coarse, like a sponge, not fine paper stuff.
Jul 30, 2009 | Dometic Rooftop RV Air Conditioner
Coleman rv roof air conditioner
(1)Check compressor contactor or relay if it stock in the close position
(2)Check for welded contact points
(3)Check switch control for defect
(4) Check if compressor contactor still geting power when it is off
Let me know what works for you.
Mar 30, 2008 | Heating & Cooling
Coleman Mach III Air Conditioner Logo
748 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
