Question about Canon PC-940 Black and White Copier
White line and very, very dirty copies
Bought on Ebay and had this problem. Shook toner, still had problem. Ordered new toner, still having problem. White line through copy and nearly black copies.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
The nealy black copies sounds like the drum is going, try adjusting the exposure to light, if it comes out with the whole page the same way but just lighter than change drum. White line sounds like there is something on the coronas.
Posted on Jul 22, 2008
Very ''dirty'' copies, despite cleaning.Black lines and black smudges all over the copies. Copier (used) delivered to me 2 days ago, does toner need to settle perhaps?
I would guess you need a new toner cartridge. Improper toner distribution would not cause the problems you are describing.
Dec 24, 2009 | Office Equipment & Supplies
White lines while sending/copying
Everything seems to indicate a dirty 'corona wire'. This seems to be the most common cause of vertical white lines running the length of a page when copying/sending. Below is a link to the User's guide for your machine with instructions for cleaning the corona and other care when using your fax machine. Best of luck.
Greg
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_2820_2920_MFC_7220_7225N_EN_1344.PDF
May 20, 2009 | Brother IntelliFax-2820 Laser Fax
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
Vertical White Line printing down the page
Hello sir; I believe you have running out toner , try put a new one see what's happen.
Feb 03, 2009 | Canon FAXPHONE L80 Laser
Dirty Copies and Black Line in Middle
the electrostatic drum probubly whent out if it was a cheap copier get a new one if it was expensive have it serviced or replace the drum yourself
Jan 22, 2009 | Canon PC-940 Black and White Copier
On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Jan 16, 2009 | Office Equipment & Supplies
Vertical lines on photocopies/faxes
The MFC-7420 Manual recommends cleaning the scanner glass and white plastic bar above it with isopropyl alcohol. Page 11-22 has a diagram.
I am having a similar problem but cleaning it did not work. But try that first.
Oct 15, 2008 | Brother MFC 7420 All-In-One Laser Printer
Toner low???
How is the copy quality? Are copies light? If so then the toner hopper is not adding toner to the developer assembly in which case you must call a tech. If the copies are fine then the toner sensor is dirty or faulty and must be replaced.
Jul 11, 2008 | Canon 3045 Black and White Copier
Blank trace appears on printed copy
replace the toner cartridge, this is a case of low toner.
NOTE: you should never clean the drum on the toner cartridge it is sensitive to light and touch.
Jan 07, 2008 | HP LaserJet 1020 Printer
Printed pages look dirty
That black dust that fell out is the toner. When you shake a toner cartridge that shouldn't happen. It looks like you have a faulty toner cartidge and that need to be replaced! Now to make your printer prints cleanly and clearly after you replace the cartridge, you'll need to get someone to service the printer(the faulty toner cartridge more than likely spilled toner on your internal printer parts, cause the smudges). Sevicing would mainly entail, taking down the printer and removing any spilt toner! If you feel you are up to this, be cautious, because toner can be hazardous to your health if you accidentally breathe it in! hope this was helpful! regards babb
May 10, 2007 | Brother MFC-7820N Laser Printer
Canon PC-940 Black and White Copier Logo
312 people viewed this question
old marine
old marine
