Question about Pentax ME Super 35mm SLR Camera
Pentax me super camera
Hello, can I use any flash configured for a hot shoe mount on my pentax me super cameras? pentax is listed as a dedicated flash. thanks, judy
    Scholar:
  • 58 Answers
Yes. Almost any flash unit will work. It only need a proper hot shoe.
Posted on Jan 21, 2009
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey judyrosebudd,
You should be able to use any flash that is not dedicated to another camera manufacturer. Even though the manufacturer lists this camera as a dedicated flash unit it still has the sync contact in the center of the hot shoe mount, which is all that is required to operate a all manual flash. This being said a dedicated flash should provide much more advanced options and simplicity of use. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 23, 2008
Flash for mamiya 7
As with most cameras, the flash for a Mamiya is universal. Any flash with a hot foot connection will fit onto the camera, and function on the camera's shoe mount. You may alternatively use any flash which has a PC sync cord to plug into the PC sync socket on your camera, it just depends on whether you want to use a camera phycially mounted on your camera, or an off-camera flash.
The flash shoe on the Mamiya 7 isn't an "intelligent" type, meaning it only has the standard single contact and doesn't communicate any exposure or other information between camera and flash, so even the cheapest off the shelf shoe-mount flash will work just as well as the most expensive. Even specialized dedicated Nikon, Canon, and other brand "dedicated" flashes with multiple contact pins will also work, only the functionality of the information communicated through those other pins will be lost.
Sep 16, 2011 | Mamiya 7 II Medium Format Camera
Can I re-mount thot shoe that went off my Pentax *istD by myself?
Its it a good camera. So dont try to re-mount the hot shoe by your self. Please contact Pentax service center.
Feb 01, 2010 | Cameras
I have a plan to get PENTAX AF 500 FTZ flash. i have a doubt if this model will be fine working for my sony alpha 200 DSLR. kesavan b
Check the configuration of the hot shoe on the flash AND the camera. The only issue you should have, is setting up for the heat range and the syncronizing speed.
Aug 10, 2009 | Pentax AF-500 FTZ TTL Flash
Sunpak 344D Pentax K20D dedication
Seems like you may be ok. Google pentax k20d supak 344d compatability.
Jul 19, 2009 | Sunpak Cameras
Where can I purchase a flash for ricoh model KR 5 super2
prasadsu,
any camera store will have a flash for your KR5. buy a non dedicated type that fits on the hot shoe.
or try ebay for a used one.
Jan 30, 2009 | Ricoh KR-5 SUPER II 35mm SLR Camera
Sunpak 383 problem
Try to trigger it by shorting Center of shoe mount and the side terminal with a small wire.If it is firing the flash is ok.
If not there is open connection in the sync jack ,due to repeated inserting of sync chord.The springy part inside is not going back to its normal position.
You can fix it your self by opening it(adapter only)
.If you are new to this take a photo of the wiring immediately after opening the shoe adapter to see the position if any wire breaks later on.
Do not give up .383 is great flash
Nov 05, 2008 | Sunpak 383 Super Flash
Connect these external flashes...
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable - this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Connect to external flashes
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Connect a FL-20, FL-36, FL-40 or FL-50 dedicated external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-750 Zoom. FL-CB02 Hot Shoe to TTL Cable -this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Connect an FL-20, FL-36, FL-40 or FL-50 external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-5060 Wide Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Pentax ME Super 35mm SLR Camera Logo
239 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
