Kohler 800 generator stops running - Heating & Cooling
  • 154 Answers
Are you overloading it? What kilowatts is it and what are you plugging into it?
Posted on Jul 22, 2008
Have generator showing emergency stop code and will not start.
there are too emergency stop sensors on generators
one is over load
the other is low oil level in the sump (Low oil pressure)
That sensor is known to trigger and activate the emergency stop so check it out after you check the oil level in the sump
Feb 26, 2015 | Kohler 20resa 20kw Home Emergency Backup...
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
Kohler 15RES LP generator runs for 10 sec and shuts down UV undervoltage. Was backfiring intermittantly. Changed out 2100 controller($800). Same problem. Tech came out and before starting the unit changed...
If you have already paid $800 for a controller that did not need to be replaced and are facing an additional cost of $5,000 for replacement of a stator and rotor that may or may not solve the problem, it might be time to consider replacing the generator.
Feb 13, 2014 | Electrical Supplies
First start up
Try disconencting the remote start wires between the transfer switch and the generator, if ot still does it you have a bad control board. If it stops, then check the transfer switch for correct wiring of utility and generator power wires, also check with an ohm meter if the run contacts in the transfer switch are closed, that would indicate loss of sensing, or bad board
Jul 19, 2013 | Kohler Electrical Supplies
Kohler gen starts runs 3 or 5 to 6 seconds then stops. its a 4000 R. V. mycro
Check oil and pressure switch, then stator for AC output, rinhs and brushes.
Feb 15, 2013 | Kohler Electrical Supplies
Kohler marine generator troubleshooting
I have a kohler marine generator that shuts down when it reaches operating temp of 200/210 degrees. It runs for about 5 minutes. Already replaced impella and have sea water pumping through, coolant level is good. Any suggestions? Thanks
May 02, 2012 | Electrical Supplies
Kohler Confident 7 model 7CCKM22 generator
sounds like a relay should be latching one it has started
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Kohler 12res AC breaker flipping with no error listed
wat size c/breaker
6600 divide 240 = amp
rule of thumb
Aug 16, 2009 | Kohler 12 kW Emergency Power System -...
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
