Question about HP Photosmart C4280 Aio Printer
Loud clicking noise after a paper jam
Theres a clicking sound now after i fixed the paper jam, now it wont print anything
  • ncsu1982 Aug 04, 2008
    I didn't have a paper jam, but I do have a loud clicking on power on. Prints fine though
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Is this still an open issue?
Posted on Aug 20, 2008
My CanonPC940 won't grab paper and push it through to print-also makes a a loud "grinding" noise. How can I fix this?
Sounds like a tire may have slid off of a wheel. Yes they have wheels. Also paper soaks up water like a sponge always keep your paper in the wrapper it comes in and the top side of the paper is where the seam is. Make sure you put the paper in so that the top side is the side going through the machine. I do how ever believe you have a wheel or gear out of place.
Oct 15, 2015 | Canon Office Equipment & Supplies
My Dell 2135cn printer all the sudden started making crazy loud grinding noises. Then I got a paper jam. I fixed the paper jam and tried to print again, but got the loud grinding noises and paper jam...
Refer to the service manual in disassembling the device.. Clean it thoroughly then try it again.. If, you have no experience in doing so, hire a qualified tech to do so.
Jun 17, 2011 | Dell 2135cn All-In-One Laser Printer
I have an epson stylus cx6000, after I put in a new ink cartiage it started making a loud grinding noise an now it won't print.
Sounds like a cartridge jam. Remove the cartridges and look at the carriage path. Make sure there is no paper or anything else in the way.
Sep 10, 2010 | Office Equipment & Supplies
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Paper jam with out paper
This is almost certainly a broken latch on the right of the carriage - it should get pushed forward by the left back edge of the cartridge mechanism as it reaches the right side. There are other examples of this described in many similar posts on various sites - including some with photos. Try and find another psc all-in-one and look at it. I have the same problem, and have 'mended' the latch so that the paper error disappears and it prints, but I have not yet solved the loud clicking
Richard
Mar 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Paper feed
Hi there.
First of all pull out the paper jam cover - is behind the printer with a clock-like handle. Pull it out and check for any paper or other objects. If U dont see anything try to manualy rotate the black rubber rollers and check for that noise. Locate it and try to describe what you see.
Jun 28, 2008 | HP PSC 2175 All-In-One InkJet Printer
Hp psc 2210 printer jam
your printer need to be opened and check for any lever is struck or dislodge, it will be better if you send it for servicing
May 01, 2008 | HP PSC 2210 All-In-One InkJet Printer
Loud noise/paper tray not working
What error? Does it say paper jam and a number? Have you tried cleaning the rollers that pick up the paper? Use a cotton cloth with a little bit of WD40. Then a dry cloth to remove residue oil. Do not use alcohol. It will dry out the roller and make it slick.
Aug 08, 2007 | Ricoh Aficio AP410N Laser Printer
HP Photosmart C4280 Aio Printer Logo
423 people viewed this question
Seeker5211
Seeker5211
