Question about Electrical Supplies
Silly problem with sanding band
This must be so easy/obvious that the instructions are not provided. However, I can't figure out how to switch out the sanding band on the sanding drum mandrel. I got the old sanding band off, but can't figure out how to get the new one on!
Thank you very much,
Bonnie
  • 163 Answers
Make sure to loosen the screw on the end of the mandrel. After removing the old sanding drum, gently roll the black rubber between your fingers to compress it slightly. The new sanding drum should slide right on and then tighten the screw.
MM85
Posted on Jul 22, 2008
Need a manual for a Techinque Pressure Cooker 65fj
If the manufacturer has a website the operating instructions should be available from there but don't despair if not as most pressure cookers are so similar to each other the operating instructions from just about any will provide an adequate overview and list the essential safety precautions.
I like my pressure cooker (Prestige) but it scares my wife silly as she has heard horror stories about black eyes and scraping dinner from the ceiling.
If you can't find instructions please comment and I will come back and try and provide a few pointers.
May 18, 2016 | Crock Pots & Slow Cookers
How do I use it?
If you are talking about Rainbow loom, or a similar rubber band loom, all the printed instructions are hard to follow. Try youtube. The kids are better at explaining than the adults. This girl is quite easy to follow http://youtu.be/ukv83Cvq3jk
Oct 07, 2014 | Toys
When you turn on few second its automatic turn off?
sounds silly but try a new battery my wife and i have the same battery's in our cameras one of us charges theirs the other don't when she has that fault she grabs my battery fits it and the camera is fixed .I hope its that easy for you the other problem she has had is sand in the lens protector if it is jammed the camera switches itself off clean it
Nov 10, 2011 | Canon PowerShot A3100 IS Digital Camera
I just bought a Tfal Ultimate Autoclean iron FV 9450. I am reading through the manual and trying to figure out all the parts and functions. I cannot figure out how to remove the anti calc valve. I...
Anti-calc valve wings (grip) located at #3 of the 1-15 labeled description diagram that is part of the instruction manual. The wings are on either side of the dry/steam control #4. Lift up on the wings (grips) and the dry/steam control will accompany it. The anti-calc valve is under this control. It's easy once you realize where the silly thing is actually located.
Jan 15, 2011 | Vacuums
I need an sanding belt 1/2 inch by 80 inches for a Sears Band Saw. Sears parts said to type in the model number of the Band Saw and all I get are instruction on how to become a MODEL Where are the sanding...
You might have better luck at your local Ace hardware. they can get the belts, also, there are belt makers on line that make any size belt you want, and grit, any type, I can't remember the name, but I'm sure it come up under a sanding belt search, Sometimes they have a minimum order, but if you can't get one from anybody else, check them out. I think it was Sandpaper America.
Aug 13, 2010 | Jet PB85 Portable Band Saw Model 414496
The metal band that holds the muffler in place has rusted out. it looks fairly easy to replace. is it as easy as it looks, and is the part easy to order, and what's the official name for this part?? ...
for some silly reason, the actual correct part for this only comes with the new muffler from the dealer. you need to go to a parts store and buy a universal muffler hanger to rig up. good luck!
May 10, 2010 | 1997 Saturn SL
Head lights only work on high beam
Im gonig to start out with a silly question so forgive me, Did you check the fuses? (I just didnt want to assume)
It is common for these headlight switches to have problems when the contacts inside get dirty.
If it is anything like the pickups and pathfinders you can remove the plastic cover plate on the back of the switch and carfully clean the contacts with some fine sand paper. usually works for a couple of years..
Oct 24, 2009 | 1986 Nissan 300ZX
Cant figure out how to install the sanding disc's
This info may help;
Features: DeWalt D26451K 5" Random Orbit Sander Kit
  • 3.0 Amp motor operates at 12,000 opm providing ideal sanding speed for smooth finish
  • Textured anti-slip top & body grip provides ultimate comfort and control during prolonged use
  • Controlled Finishing System maintains pad speed and minimizes gouging during start up
  • Dust-sealed switch prevents contamination
  • Sealed 100 percent ball-bearing construction provides longer life
  • High capacity dust bag with built in vacuum adapter provides maximum dust collection with or without vacuum
  • Dual-plane counter-balanced fan reduces user fatigue
  • Accepts 5", 8-hole hook & loop paper allows sanding discs to be switched back and forth quickly and easily
  • The sanding discs mate to the sander plate similar to Velcro, and this particular sander uses a 5" disc with 8 holes in it. Can be purchased in Home Depot, Lowes, etc....
Hope this helps!
Jul 23, 2009 | Dewalt d26451k 5" random orbit sander kit...
How to load tape
it's not obvious indeed!
The idea is to;
1. take out the ring (try it by releasing the back part first! easy does it.
2. put tape into the Dymo 1855 mk II by pressing the white lever down
3. then take the tape you pushed through and guide it through the ring.
4. Put the ring back into the Dymo.
It worked for me ;-)
Good luck,
Marc
Nov 16, 2008 | Office Equipment & Supplies
Electrical Supplies Logo
54 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
