Canon i 560 printer
Paper not feeding through therefore not printing. Starts to feed through but is crooked and then stops.
  • 813 Answers
U have to change the roller of your printer to change it u have to for a professional printer repairer
Posted on Jul 22, 2008
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Every time I try to print I get a paper jam.The paper starts loading but then goes crooked and gets stuck. Error 3 comes up on the display.
sounds like one roller is pulling more than the other, which is why it starts going crooked. You may have to replace the roller, or the entire feed assembly. not sure which.
you could also try cleaning the rollers with alcohol, ... see if that gives them a little more grip.
Sep 24, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper feeding crooked and not printing
then you to consult your manual of your printer and you will unscrew it to correct the paper carrier and to see the technical timer to be corrected.
Jul 09, 2009 | Canon Pixma MP480 All-In-One InkJet...
Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Jun 21, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Printer either eats up paper or won't print anything out
what you might try is to find some thing that has been laminated on both sides and manuall feed it in to the feed rollers and see if you are able to push out what ever is in the paper path making your paper go in crooked. brother tech
Jan 17, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Paper feeding crooked and jamming in my Canon IP6600D printer.
Try doing a thorough cleaning of all the rollers in paper path making sure that there also no scraps or obstructions in the path.
Aug 31, 2017 | Canon Pixma iP6600D InkJet Photo Printer
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
70 people viewed this question
jasbo
jasbo
