Question about Mitsubishi WS-65809 65" Rear Projection Television
Tv bows picture bows down from the top and bows up from the bottom
  • 3 more comments
  • rockinanreel Aug 11, 2008
    I have the same problem but know nothing about tv repair. I don't want to spend to much on repairs so I would like to know is it worth it
  • bdabrian Aug 20, 2008
    Same problem, started a couple of weeks ago and would go away almost immediately. Now it's becoming more and more common and won't straighten up at all. I haven't seen any thread addressing what the problem might be so has anyone actually taken the set in for service?
  • basstracker5 Aug 21, 2008
    same as described. picture bows up at the top and bows at the bottom. switches from top to bottom. lasts longer some times than others. tried doing the convergence and that did not help.
  • eezzz1 Aug 31, 2008
    Same problem. At first it went away when the set was turned off and then on again. Now, it appears with the bottom bows in the picture most of the time. Also does it for x-box, but very rarely for DVDs.
  • Ruthlesslv Nov 30, 2008
    It's getting to be very annoying! I've tried different formats but, the top and bottom curves are still there. I like to get fix but, like ever yone else I don't want to pay to much. $100 - 200, that's it.
  • 23 Answers
I have the same tv. I had the same problems. It started with the lettering on top and bottom showing the different colors, it progressed to the top and bottom being pulled into the middle, all this would go away, but come back, sometimes it would be when the tv is cold and at others it would do it when it is hot. It would turn on ok but then act up, it would turn on with the problem, then go away, so there was no reason for it yet there it was. It progressed to the point that it would also have lines snaking across the screen, very long lines, moving in every direction. till finally the tv would not turn on at all one day.
It produced a code of 22 when the diagnosis was engaged. (code 22= short protection), I checked the fuses(fa95a and fa94a) they were open, which ment the IC's were shorted. The horizontal and vertical deflection IC, both of them. (watch for the look in your friends faces when you you respond to there question of "What did you do to fix it" and you respond with" I replaced the Vertical and horizontal deflextion IC" it's priceless).
So you need two deflection IC's, its important to know that they are the same part and interchangable, the rest of the tv makes them do their specific job.
They can be obtained here: http://www.bdent.com/ There 16 bucks each, plus shipping and handling.
The fuses are not avialble from BDent, go figure, they would have to be obtained from some other source, I got mine from: http://www.mcmelectronics.com The fuses are not an exact replacement, but all fuses do is protect circuitry I was comfortable using a non identical part, the fuse is rated as a 5 amp fuse. It had a 250v rating also. the voltage in this case is not an issue.
If you have any experance in circuit board soldering then you can do the job. The circuit board they're on is easy to tell, its the one in the middle, It has a massive aluminuim heat sink with the IC's mounted onto them, the board has to come out, (the heat sink is mounted to the tv,thru the board), so you have to remove the heat sink seperatlly. The board has other heavy components, so care has to be used to hold and handle the board (handle it like you would a newborn, it is after all your baby!) the board is not strong enough to support the components on its own.
the total cost for me to fix my tv was under 70 bucks and i also ordered the servive manual, My training is in Avionics, but if you have some soldering experiance or a friend who has some, a friend who does a/c tech , or model airplane as a hobby he can help, just watch those a/c techs they can use too much force sometimes. If your not able to do the job it's worth paying someone to do it or parts of it with or for you. If you take the board out expect to put it back. It's still a great tv and to have it up and runing, well I don't have to tell you how it feels. Replacing it is not an option, it cost me 2800. and that was only 6 years ago, when i opened the tv it was in great shape inside, no leakage from the guns, no excess dust, just looked new.
If you live in any state surrounding Indiana I'll do it for 500.00. from here to ny city-700.00.
Posted on Dec 01, 2008
Bdabrian,
As was stated by Irish, sounds like convergence IC's need replaced
Posted on Aug 21, 2008
  • 927 Answers
Good Day, rockinanreel;
Most TV repair shops charge somewhere between $450.00 TO $700.00 and more. It will depend on your location an type of shop. Stay with an authorized service center and ask before hand what the charge for the repair of changing the convergence IC's.
Good Luck, big IRISH.
Posted on Aug 12, 2008
The top of the picture is bowing down, and the bottom of the picture is bowing up, and throwing the convergence out. What is causing this?
The 2 STK convergence ICS and some or all it resistors are the cause and is dead.The tv convergence board require these parts to be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 13, 2010 | Sony KP-61HS30 TV
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Cheap Fix?
I will strongly advise you to replace the two STK392-120 as a pair. and this will cure your bowing picture problem. You may need to re-converge your set. best of luck.
Nov 05, 2008 | JVC AV-48WP30 48" Rear Projection...
Tv is messed up
I got a question.
Do you have any stereo speakers anywhere near your television?
This sounds like something a magnetic field could cause from speakers being too close to the tv.
If so try to relocate them and see if the problem goes away.
Jun 15, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bowed picture
malfunction of the pinchusion circuit.check pinchusion diode and transistor and pincushion ic
Dec 23, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Horizontal bow and shadow
Replace convergence IC's--then re-check convergence alignment in servicer mode,if necessary.
Sep 27, 2007 | Philips 9P5544C 55" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
