Philips plasma tv vertical black stripe
I have a vertical black stripe about 3-4 inches wide right of center on screen that wont go away. Have a Magnavox with same problem, but only half of screen, 3inches wide. What did the repair cost?
  • 2 more comments
  • tkyleq Jul 22, 2008
    Helpful guidance, THANKS!
  • danims7 Aug 06, 2008
    I have the same problem with my Philips LCD screen. The left center it starts out with vertical stripes of different colors then it goes black. Sometimes it goes away.
  • Anonymous Aug 19, 2008
    I have the same problem myself. Have a 2-year old Panasonic plasma TV (TH-42PX60U) and now I have a permanent vertical black stripe along the left hand side...plus the shadows. I've disconnected everything and tried to "reboot", but not working. So disappointed in Panasonic because this TV is so highly rated on Consumer Reports and CDnet. Was anyone able to fix? What did Panasonic do to keep you as a customer? I'll don't think I'll buy another Panasonic again if they don't do the right thing.
  • Anonymous Sep 04, 2008
    I have the same problem with my 3 year old LG LCD TV. The qualified repair center said the LCD screen itself is broken because of micro-cracks which are formed because of heating up and cooling down. It can be repaired by replacing the entire screen which is more expensive than a new LCD TV. Philips TV's have the same problem because they come out of the same factory.
    So my TV, which was supposed to last 50,000 hours, is now broken after 3,500 hours or so. Thank you LG.... NOT!!
  • 3 Answers
Check these videos for repair instructions for black lines.
Just requires some soldering.
Video 1 / Part 1
http://www.youtube.com/watch?v=9NPobj0_GSo
Video 1 / Part 2
http://www.youtube.com/watch?v=ITd6Ahdi4s0
Video 2
http://www.youtube.com/watch?v=qBpg77ZzFFk
Posted on Feb 09, 2009
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
Posted on Jul 22, 2008
    Problem Solver:
I have a lg 42 inch plasma that had the same problem. I was told that the panel was bad. I replaced the digital board for $108.00 and it has been workin fine for months now. owuzzi50@msn.com .
Posted on Oct 15, 2008
I have the same problem with my 3 year old LG LCD TV. I brought it to a certified repair center and they said the screen is broken because of micro-cracks which were formed because of heating up and cooling down. They said Philips and LG have a whole series of TV's with this problem. Repair is possible by replacing the entire screen which is more expensive than an new TV...
So a TV which is about to last for 50,000 hours broke after only 3,500 hours : (
Posted on Sep 04, 2008
I have a 52 inch Samsung TV, on the screen have solid, color vertical lines on the right, about 1/8 wide, on the same time the half of screen blink on the right too.
not knowing the model... i will try to help with this common samsung issue, if i can. / unplug the tv, and wait a few minutes to avoid shocks. / remove back panel. you will see several ribbon connectors, (about an 1" to 1 1/2" wide) usually near the bottom. / carefully remove the ribbon (ONE AT A TIME) and clean the contacts GENTLY with a pencil eraser. (DO NOT use chemicals) / reinsert the ribbons and try the tv. // vertical stripes are almost always the result of poor contact between ribbon and socket. / NOTE!. you can do a quick test before opening the set by [carefully!!!!] twisting the screen and watch to see if the vertical stripes change or disappear. / if the stripes change, bet on it being the ribbon contact problem.//// hope this helps, it has worked on a number of TVs.------Jay
Oct 26, 2015 | Samsung Televison & Video
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Inch wide vertical white band on my Imac screen?
If the white band appears right from start up, the display needs to be replaced, if it comes on after it starts, it is most likely a software problem.
Feb 16, 2009 | Apple iMac G5 Desktop
Magnavox 42MF7000/17 Green Stripes Pixel down section of display
Possible Defect in programing. Call Manufacturer for possible support in Updating Firmware.
Jan 18, 2009 | Philips Magnavox 42MF521D/37 Television
Right half of screen blanks out
Hi...there,
Well... after 3yrs of used, it's time to retired. You've got a busted panel...
Dec 01, 2008 | Philips 230W5VS (Silver) 23" LCD Monitor
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Apr 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
5,028 people viewed this question
Top Televison & Video Experts
Electro Med Services...
