Question about Canon Office Equipment & Supplies
I have a canon i560 bubble jet printer and the paper is not feeding through. It starts to feed through and then goes crooked and does not feed any further.
  • 813 Answers
U have change your roler of your printer & your problem will solves to change roller of printer u have to go with a professional printer repairer he will charge u for this 100$ to 200$
thnx using fixya
Posted on Jul 22, 2008
  • 790 Answers
Hi
Maybe the sensor is too dirty and need to cleaning the sensor...
Thanks!
Canon MP210 takes paper crooked and spits out crooked or jams. How to fix? Followed manual for cleaning feed roller but to no avail. Thanks
could it be a paper clip fell into the paper feed slot? see if you can shine some light into the slot and use a dentist's angled mirror to examine. sound like debris may be the culprit. disassemble it to the extent that you have ability to. LEARN THAT WAY!
Feb 12, 2015 | Canon PIXMA MP210 Photo All-In-One Printer
Paper going in crooked
Adjust the side guides in the paper tray up against the paper snugly. If it still feeds crokked try feeding paper through the hand feed tray.
Dec 27, 2012 | Office Equipment & Supplies
The paper does not feed correctly so that the paper goes into the machine crooked causing a paper jam.
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Aug 27, 2011 | Canon Office Equipment & Supplies
After I ran out of paper the machine will not restart
Did you press the paper feed/resume button? It will not restart by itself.
Nov 19, 2009 | Canon BubbleJet i560 InkJet Printer
Canon Bubble Jet printer won't feed paper and print properly.
Hello sir; You need to clean up paper pick up roller and feed roller with alcohol, if still have problem then replace it.
Nov 07, 2009 | Canon BJC-85 InkJet Printer
Paper feeds crooked and results in a paper jam.
Assume every time this happens something microscopic fell into that tiny pinch of an area. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over and shake it around til the little bugger falls out.
Oct 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Every time I try to print I get a paper jam.The paper starts loading but then goes crooked and gets stuck. Error 3 comes up on the display.
sounds like one roller is pulling more than the other, which is why it starts going crooked. You may have to replace the roller, or the entire feed assembly. not sure which.
you could also try cleaning the rollers with alcohol, ... see if that gives them a little more grip.
Sep 24, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer won't feed and makes a strange grinding sound
Its probably just old and worn out. They dont even make bubble jet printers anymore. Printers are cheap now anyway. Go to www.tigerdirect.com and you can get a printer for around 50 dollars.
Apr 10, 2009 | Canon Office Equipment & Supplies
Won't feed paper
ok, you will have to preform a hard reset by unplugging this printer and let stand for five minutes. plug back in the socket after this period and restart the unit. if the problem persist, you will need to download the new drivers and firmware on the manufactures website.
Mar 03, 2009 | Canon BubbleJet i560 InkJet Printer
Paper feeding crooked and jamming in my Canon IP6600D printer.
Try doing a thorough cleaning of all the rollers in paper path making sure that there also no scraps or obstructions in the path.
Aug 31, 2017 | Canon Pixma iP6600D InkJet Photo Printer
57 people viewed this question
old marine
old marine
