Venturer PLV31220S1 22 in. LCD TV Logo
Posted on Feb 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sky remote code please - Venturer PLV31220S1 22 in. LCD TV
Anonymous
Level 2:
Scholar:
  • Expert 137 Answers
  • Posted on Feb 11, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
137
Questions
Helped
58125
Points
390
Press "interactive" button on remote
Go down to 4 "customer service", press select.
When the customer service page comes up,
Go down to 5 "program your remote" then press select
Then follow the on screen instructions.
This service is free and does not access your phone line at all.
4answers
Sky remote code for my bush lc-46gl12f tv I've tryd all of sky's codes and no luck please help
try this...press TV on your sky remote now hold select and red button until it flashes tvice,now enter this code....1430...after u enter that code it should blink twice again,now press standby,if it turns your TV off,press select to save these settings, it will also control your TV volume...Let me know if this helps
2answers
Sky remote codes for television model 42PF9631D/10
Hi
The correct code (or whether there is a code at all) depends on which version of the Sky remote you are using. The version number of the remote can be found on a sticker inside the battery compartment. If you have "RC1600/00" "Rev 4" or "Rev 6" on the sticker, then it's unlikely that it will work with your TV, but please read on as this isn't always true.
If you have a "Rev 8" remote then it's more likely to work with your TV, however, according to Sky, you will need to buy the new "Rev 9" Sky remote:
http://www.thedigiboxshop.com/sky-hd-remotes-sky-hd-remote.html
If buying one, be sure to check the button for the "Rev 9" version ( £0.85).
The actual code for your TV model is: 0718
I suggest you try the above code regardless of which version of Sky remote you have as Sky's information is not always accurate. You can also try these generic codes for Philips TVs:
0584, 0266, 0065, 0749, 1679, 0199, 0679
Again, try these with whichever version of the Sky remote you are using. There is a good chance that one of them will operate the volume and power functions on your TV. If none of the above codes work, then you will probably need to buy a Rev 9 remote.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
2helpful
I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
1helpful
I am looking for the Sky remote code for a Sony KDL-40V2000 TV can you please help.
Sky don't have a specific code listed for this model yet, so the first thing to do is try the Generic Sony codes first. These are:
1679, 1533, 0678, 0681
These codes are for a "Rev 8" Sky remote. If the above codes don't work or you need further assistance, please post back and I will investigate further. When posting back, please state which Sky remote version you have and whether it is also Standard Sky, Sky+ or Sky HD. The version number can be found on a sticker inside the battery compartment. RC1600/00 is the old original. Newer remotes will also have either "Rev 4", "Rev 6" or "Rev 8" on the sticker.
Please note that Sky remotes wont work with all TVs. I've been informed that a new revision of the Sky remote is due soon but I have been unable to verify this.
Hope this helps. Please post back with the information requested above if you need further assistance.
Regards,
BElectric
2answers
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
1helpful
2answers
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
2helpful
Code for sky plus remote please
Hi, the code is 1130, i have the same television and the code works perfectly with a rev 8 sky+ remote.
7helpful
3answers
Pin code for wharfedale tv
1 am looking for the sky remote code for a wharfedale ltf42k1cb teley
Top Venturer Televison & Video Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
