Question about Canon PowerShot SD1000 Digital Camera
Black screen, not capturing photos
Cannon SD1000: Have only used it a few time, but suddenly it's stopped capturing pictures. i.e while in shot mode the display is black and not showing and capturing the image, but able to access all the menus while in preview mode able to view the images already taken.
  • Nail-er Aug 13, 2008
    I was taking pictures , switched setting to night mode, took two pictures then screen went black. Can veiw pictures already taken but through the lens veiw is not working I tried taking another picture but the pictures come out blank. Cannon was aware of this problem in 2006 and fixed it for free. Apperantly it is still an issue but instead of fixing the problem at the source the want to charge $100 to fix it.
    I've bought three digital cameras and non have lasted more than a year. I'm going back to my twenty year old 35MM !!!
Have the same problem...
it happened about a month ago and i pressed the display button and it worked, but now that doesn't work either!
Posted on Aug 13, 2008
3 Suggested Answers
SOURCE: Canon SD1000 display is black while the camera in shot mode
I had the same problem, i literally smacked the sides of it (after reading possible solutions on this page) and i turned it on and off repeatedly and i was surprised when i saw it working again! Give it a try, it worked for me
Posted on Sep 02, 2008
  • 5 Answers
SOURCE: i have a cannon sd1000 , bought 1 month back.
Stop! While you may find a fix... any camera that goes bad within 30 days be just be a sign of future problems. canon will be the first to admit that one in every few hundred cameras produced are bad and therefore customers should exercise their warranty. Return it!
Posted on Jul 21, 2009
Hello, I have a Canon Power Shot sd1000 Digital ELPH. I cant get the time and date stamp to print on the pictures. How can I fix this?
If the pictures are the ones you have shot without time and date stamp, you can't add them by your camera then. You only can add them by your computer.
Aug 31, 2011 | Cannon Cameras
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
Cannon sd1000 lcd screen black. Can review pictures, but cannot take new pictures.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2010 | Canon PowerShot SD1000 Digital Camera
I have a cannon sd1000 , bought 1 month back. suddenly its stopped capturing pictures. i.e while in shot mode the display is black and not showing and capturing the image.but able to access al the menus....
Jul 17, 2009 | Canon PowerShot SD1000 Digital Camera
Sony T3 cybershot screen black
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=7&NAVDISP=di
Mar 11, 2009 | Sony Cyber-Shot DSC-T3 Digital Camera
Cannon powershot sd1000 date stamp
No, you can't while they are in the camera. Date and time are added by the camera when it captures the image, so if you didn't have the time/date stamp on when you took the picture, it won't be there. What you could do is upload the pictures to your computer and add the date and time yourself in Paint, IrfanView or another similar program.
Jan 15, 2009 | Cameras
Cannon Power Shot A560
Did you accidentally hit the lower left "Disp" button on the back of your camera? It manually turns the screen on or off to save batteries. Turn the camera on and press it once to check.
Jun 18, 2008 | Cameras
After some inspecting of the camera it seen the issue lies with the lens, not the camera itself so don't go banging the camera up or you might damage some other part and the camera will be broken for real. Inside the lens is a closer which block the internal system from capturing image. The closer look just like the one you see before turning on your camera but it's smaller and it's inside the lens way in the far back. Look carefully and you'll see it - you will see the closer if your screen is black while in capture mode otherwise you will see a nice round glass (the internal lens for capturing image/video).
Think of if like this, imagine an eyeball with its eyelid close. That's what happened when the screen is black while in capturing mode.
HOW TO FIX IT: In order to fix the black screen while in capture mode and cost as little damage to your camera as possible, simply turn on the camera in either picture or video mode and look inside your lens, there should be a closer in the far back end. Gently hit the lens a few times until you don't see the closer no more and only a round glass and your camera should begins capturing image and video again.
Good luck to you all. And remember don't use anger to force your camera to works or you will regret it.
If you need further help, contact me via email y a j y e e (at) h o t m a i l (dot) com
Yee Yang
May 13, 2008 | Canon PowerShot SD1000 Digital Camera
Night photo's without the camera shake
Dont use night mode because shutter takes more time to capture.I advice u to use AUTO mode during taking pictures alltime.
Sep 10, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
350 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
