Question about Garmin Nuvi 350 Car GPS Receiver
Nuvi 360 how do I open to fix the power button - THX
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Note to all Garmin Nuvi 350 Users with a Defective On/Off Switch:
    1. In order to repair this problem, you need to have surface mount desoldering/soldering skills as well as the appropriate soldering tools and case dissassembly tools. Without these things, you take the risk of further damaging your Nuvi, possibly making it impossible to repair.
    2. Resoldering the switch is not going to resolve the issue long-term. In some cases, the switch can not be resoldered and additional rework must be performed.
    3. In order to fix this problem once and for all, the switch needs to be mechanically secured better to the main PCB using pre-tinned buswire. In addition, a custom-fit piece of plastic needs to be glued behind the switch to give it additional support.
    FAILURE TO DO THE ABOVE WILL RESULT IN THE ON/OFF SWITCH BREAKING AGAIN.... GUARANTEED!
    For a reasonable price, I will repair youf Nuvi on/off switch and put in the modications so it doesn't happen again. Repair takes 1 day, units are sent back the next day. Please contact me at KS3R at sharc dot net if interested. I have references.
    - Jim
  • SHARCNET-USA
    I would not attempt this repair yourself unless you have soldering skills and experience with surface mount technology and the proper equipment to unsolder & solder surface mount parts.
    You take the risk of further damaging your Nuvi.
    - Jim
My garmin nuvi will not shut down. The screen is white. Is there a reset button on the unit?
In some nuvi models there is a reset button.But in some nuvi models there is no reset button.you have mentioned only garmin nuvi but not mentioned the model of the garmin nuvi.But still i will mention the reset button location of some garmin nuvi models.Hope that helps you.
The reset button/procedure for garmin nuvi models
In order to reset Garmin device or enter into maintenance mode, perform one of the following procedures:
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin Nuvi 660, 680 series.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin nuvi 200, 250, 360 750, 760 series unit. Garmin Nuvi 360 on how to perform the hidden reset function.
Reset button on the bottom of the nuvi backside.
Click on the link below to get the exact location of the reset button.http://www8.garmin.com/manuals/1512_SetupandGo!.pdf also check out this link too http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf Thanks. keep updated for any more query.you can rate this solutionand show your appreciation.
Jun 11, 2010 | Garmin GPS
Reboot the Nuvi 360 to "Mass Storage Mode"
1. Connect Nuvi3xx to PC vis USB Cable for 7xx to go into
mass storage mode.
2. Slide Power Switch to the right (LOCK Position)
3. Click the "Safely Remove Hardware" icon in system
Tray on PC (Lower Right)
4. Click on "Safely remove USB Mass Storage Device -
Drives(x:and y:)" x: = mass storage for the 3xx and y: = the
SD card if one is installed
5. WAIT for 3xx to Boot UP.
6. After 360 Boots UP slide power switch to center
position
Sep 30, 2008 | Garmin n vi 360 GPS Receiver
The touch screen of my nuvi 360 go crazy when antenna is open
Going to say it's rf interferance that makes things go crazy. If the gps unit works fine witrh the antennae in the down or closed position then leave it like this. If not you might have to try moving the unit around to different spots on your dash and hope that one of them will work. Oh as to the reason, the plastic is a little thicker on the back of the unit wqhere the antennae is and the antennaes power when it is up is able to radiate a little better since the top of the antennae is the part that gets the power.
Hope this helps
Mar 12, 2010 | Garmin NUVI 360 GPS Receiver
Nuvi 360 stuck in simulator mode
Please see this link:
http://www.sharc.net/discus/messages/6/307.html?1252938489
If that doesn't resolve it, let me know:
- Jim
SHARCNET-USA
Oct 10, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin c550 GPS-Won't turn on at all.
push and Hold the power button down while you push reset, keep power button pressed til it boots again. If it does not, and it's in warranty ship it to garmin. If it's out of warranty, have someone open it up and remove the battery for a couple of minutes.
Jun 29, 2008 | Garmin nuvi 350 GPS Receiver
Nuvi 360
The screen has two connectors, one for power, another for data, just try to reconnect again those little cables, and it should be fine. When I opened mine the first time, my screen comes up all white, and it was because one of those cables.
I have a video from the last time I open my Nuvi350, I will try to post it on this days, in order to give you some idea on how to do it.
By now, I wish you luck, and be patient.
Jun 26, 2008 | Garmin nuvi 350 GPS Receiver
Unlock a second hand nuvi 360
i have a garmin 360 and dont now the pass word is their any way to unlock it with out nowing the password
May 11, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin Nuvi 350 Car GPS Receiver Logo
145 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
