Question about Logitech QuickCam Connect Webcam
Why after puting in the cd and going 2 install & clicking on it ,it will not install
  • Anonymous Sep 07, 2008
    cannot install logitech quickcam connect error message 1720
  • BRIAN REISS
    BRIAN REISS May 11, 2010
    I HAVE A SOLUTION, BUT NEED TO KNOWN YOUR OS, IF IT'S WIN XP OR WIN VISTA? REPLY TO ARCLIGHT1217. I CAN THEN ANSWER YOUR PROBLEM. THANKS!
    Genius:
  • 1,061 Answers
When installing cam drivers from disc cam must be unplugged or drivers will not lnstall properly.unplug the cam and uninstall drivers.download new drivers reboot.once you have rebooted plug in cam the os will see it and install drivers if not go into device manager and find cam click on and chose update driver they will install.reboot.all should be ok but if not i can asssist further. always glad to help.RICHARDM69
Posted on Dec 06, 2008
I have just puchussed sims 2 for pc and was not told it wont play on windows vista, it keeps telling me i can download a program to play it. Not sure which 1.
When I tried to install The Sims 2 on my pc while using Windows Vista I had a problem. When the installation reached 1% a message appeared saying: "A problem occured when trying to transfer the file 'F:/Support/es/Leeme.txt' from the media. Do you want to retry to copy the file,or cancel the installation?" and the installation couldn't go on because you had only 2 choices, retry or cancel. The problem actually is with the name of the file. In the cd/dvd the file has the name 'Leã©me.txt' but in the installation the file has the name 'Leeme.txt'. What you really have to do is:
1.Open 'My Computer'
2.Right-click on the cd/dvd drive with the game in it and hit Open
3.Copy all the files of the game 4.Go to desktop, right-click and hit New<Folder.Rename the folder Disk 1
5.Paste the files of the game inside the folder
6.Go to Support<es and rename the file 'Leã©me' into 'Leeme'
7.Go to Support<sv and rename the file 'lã¤smig' into 'lasmig'
8.Remove the cd/dvd from the drive
9.Start the installation from Disk 1<AutoRun.exe
The installation should now work properly until the end.
But when you try to run the game a message will appear saying 'This program has known compatibility issues'. Click check for solutions online and then follow the link that appears.This link provides you with a patch for the game!
Aug 06, 2011 | Video Game Consoles & Games
Get insert disc into drive D when the disc is in reads CD;s but not DVD's
Method 1 :
If your drive reads cd's, but not dvd's That indicates that the hardware works fine. You will need to edit the registry inorder to fix this problem.
1) click the start menu
2) click on "run"
3) type "regedit" and click ok
4) go to string key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5) delete "upper filters" and "lower filters in the right side window.
6) right click my computer in the start menu.
7) click properties
8) go to the hardware tab
9) click device manager
10) expand the dvd/cdrom drives
11) right click the dvd rom and click uninstall
12) restart computer
after restarting, windows should automatically install a clean ROM drive and it should read DVDs just fine if you have the correct DVD decoders.
check if it works fine or else Try Method 2.
Method 2 : Just go the link below
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=INS_PNT_PM_1720
and select the Operating system and double click on "CD/DVD"
and download the firmware updates according to your CD-DVD drive Comapny and installed it.
Most probably it will solve your Problem.
Rate this Solution.
Jan 03, 2010 | Microsoft Inspiron Notebook
No in game sound
fun game isnt it? There is a few possible problems, one your cd is scratched, two you hav'nt set it up in your game options.the last thing is it could be your computer.(in that case i cant help you) sence you said "I've never had this problem on past computers" the most likely candidate is your cd is scratched, if so u may have to buy a new one, or WHICH I HIGHLY DONT SUGGEST, is puting a very very very very small amount of butter on the cd and rubbing it in, you see a cd is a serries of bumps and indentations and the computers reads these bumps and indentations to tell it what to do, when a cd gets scratched, it makes some bumps broken or make them read as indentations, puting butter on the cd fills in the indentations that should be bumps, thus solving the problem. the other thing is yourin game settings, while you are in a game, click on the top right(i think) to get to your options you should have one sub heading called settings click one it, then look for voice options or somthing simmilar to that and turn the valume up, the same goes for battle sounds
Dec 21, 2009 | Microsoft Age of Empires 2: Age of Kings...
How can i install audio divice by motherboard cd
Installing a driver is not a problem...
simply open my computer, and autorun the cd (If Autorun is enabled)
If Not, Follow these steps :
-Go to my computer,
-Right click, go to its property,
-Go to devie Manager, Click Yes to .UAC notification.
-Now go to sound & audio, expand it.
- When u find ur prefered audio device, select it & make a right click over it,
- Now click update driver,
- follow the steps & let it search the best driver from the CD
- Be patient as it would take time to surf 700MB's of cd.
- After this is done, it will install the driver software & its done..
Restart Ur System & its done..
And My Personal Advice For Vista Users,
Turn off the .UAC notification that comes everytime u click somethin to install or somethin, its really harassing.
To Disable it Follow these steps (It wont Hard Anything)
Click on start
Click on ur Photo (User Account Control)
Once it gets open, select ur profile,
U'll see a tab,
TURN OFF/ON USER ACCOUNT CONTROL FEATURE
Open it & unmark it..
Restart it & see how fast ur system can be
Hope This Helped u out...
Thanks....
Aug 27, 2009 | Acer Aspire 4315 Notebook
I lost my cd for a4tech cam
1. Go to: http://www.a4tech.com/ennew/downloads.asp
2. Under the"Downloads" section, you will find 2 fields. Click the arrow next to the field labeled "SELECT" & choose "PK" from the drop-down menu.The second field will display "130MG". Click the arrow next to this field & select "5" from the drop-down menu.
3. Click the "GO" button.
4.In the next page: in the orange side-bar to the left you will find your web cam model & 2 buttons. Click the button labelled "Driver For PC". This will start the download of the installer for your web cam.
Jun 21, 2009 | A4tech PK5
Install A4tech camera on my pc w/o cd driver
2. Under the "Downloads" section, there are 2 fields. For the field "SELECT", choose "PK" from the drop-down menu. The second field will automatically display "130MG". Click the arrow next to this field & choose "7MA" from the drop-down menu.
4. In the next page, in the orange side-bar to the left of the page, click the "Driver for PC" button. This will start the download of the drivers for your web cam.
5. After the download finishes, & before installing the driver, make sure that you remove the old driver from Add/Remove Programs in the Control Panel, & reboot the computer.
6. Install the downloaded driver for your web cam.
May 22, 2009 | A4tech PK-7ma Flexi Webcam
L7 wiring options
yes it should work fine i would bridge them up to 4 ohms each speaker then bridge them back bye conectin them on the amp by puting the red with the red and puting the black with the black if the amp only has 1 chanel then put both speakers red on the same positive on the amp and same with the negative now to bring the ohms up to 4 ohms conect the solid red to the black with dot with a short wire ok then the ones that are not run together will go to the amp giving offf 4 ohms and with the 2 speakers bridged together thay will reduce to 2 ohms witch means that eatch speaker will get about 600 wats of rms from the amp
Aug 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Install A4 tech PK635 M web cam without cd installer
2. Under the"Downloads" section, you will find 2 fields. Click the arrow next tothe field labeled "SELECT" & choose "PK" from the drop-down menu.The second field will display "130MG". Click the arrow next to thisfield & select "635M" from the drop-down menu.
4.In the next page: in the orange side-bar to the left you will find yourweb cam model & 2 buttons. Click the button labelled "Driver ForPC". This will start the download of the installer for your web cam.
May 03, 2008 | Philips J44414
A4tech installation software
2. Under the "Downloads" section, you will find 2 fields. Click the arrow next to the field labeled "SELECT" & choose "PK" from the drop-down menu. The second field will display "130MG". Click the arrow next to this field & select "5" from the drop-down menu.
4. In the next page: in the orange side-bar to the left you will find your web cam model & 2 buttons. Click the button labelled "Driver For PC". This will start the download of the installer for your web cam.
Apr 11, 2008 | Palm Treo 600 Handheld
Logitech QuickCam Connect Webcam Logo
75 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
