Question about Hotpoint Refrigerators
Suddenly there is a running noise inside the icemaker and the power switch doesn't work. when unfreezed and restarted runs normally but after 3 or 4 days becomes frozen and the noise comes back.....
  • memocobo12 Oct 25, 2008
    The cause of this issue was the water filter. I never replaced it and it looks it was clogged. I replaced it for a new one and now the system is running perfectly two months ago.....Hope this could be useful to someone else
    President:
  • 1,314 Answers
There are several componets in the ice maker that could cause this but takes ime and equptmend my best advice is just replace the unit its self just get a new ice maker
Posted on Jul 22, 2008
The fridge make weird noises some days. Cooling is good, freezer also works well. My concern is if those noises are prelude to a major damage.
This really depends on the type of noise. If you hear a gurgle type noise while running this is usually normal from the refrigerant pumping through the tubing. Fan type noise blowing air in the freezer section is also normal but if it sounds link the fan is rubbing or grinding you need to look into that noise. Also a similar fan down near the compressor area in the lower back section. A low hum from the compressor while running is normal. If you have and icemaker--water running noise about once per hour for around 10 seconds is all normal while the icemaker is filling. Dropping noise from the cubes falling into the bucket is also normal about once per hour. Hope this helps.
Jun 10, 2015 | Refrigerators
Icemaker starts then stops
The drop sensor is faulty, fooling the machine that the ice has harvested so it restarts. Eventually you will just have a solid block of ice. Replace sensor (magnetic reed switch)
Mar 08, 2014 | U-Line Icemaker
Hi, I have a technogym run forma. Suddenly when
please adjust the REED switch, see the diagram attached. clean it+test for open or faulty+tight very well the connection.
2) tight the ribbon cable inside from console +tight the upper and lower connector very well and clean from oxide,+corrosion
3) reset with the small switch attached to the main power switch use small pencil erase for to click.
God bless you
Aug 24, 2013 | Exercise & Fitness
A6119h power button doesn't turn on
if your want cpu run then open ur cpu change restart switch to power switch ...its work...
your power switch not be work
Jul 30, 2012 | HP Computers & Internet
When I power up the computer sometimes it just makes a beep the fan starts then everything shuts off after a few times of trying it will switch on and then just makes a continual noise and the left green...
It sounds like a power supply issue or a bad video card.If you have an after market video card remove it and run the video off the mother board.If that wont work look inside and make sure all wires are plugged in.Now if it still wont work.The last thing is a reinstall the OS.
mikespreafico@yahoo.com is my email if none of that works let me know.
May 11, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
2006 Nissan Titan alternating misfiring and running fine until !
My truck is doing the exact same thing. I have been told it is the Intelligent Power Distribution Module or IPDM. The Nissan Dealership that is working on my truck says $400.00 parts and labor to fix.
Jul 19, 2010 | 2006 Nissan Titan
Whirlpool IceMagic Plus not working.
Pour about 2/3 cup of water into the ice maker . If it dumps the ice but doesn't refill , replace the ice maker . If it doesn't dump , and the cubes stay in the ice maker , replace the ice maker .
The switch on the icemaker for normal , runs the icemaker normaly . In the ice plus , a small fan comes on , blowing the inside air , over the ice maker mold , to help it freeze faster .
Sep 14, 2009 | Refrigerators
Firgidaire FRS20ZRG Side by Side Refrigerator/Freezer Ice maker not working
reach into the icemaker and with a finger pull up on the ejector blades on the icemaker watch the blades and see if they go all the way around
Feb 13, 2008 | Refrigerators
Power problem
The CPU the next time observe to see if the fan is running......it may not and the CPU is overheating.
Oct 15, 2007 | Dell Latitude C640 Notebook
Refrigerators Logo
47 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Gil Shultz
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
