Question about HP Officejet 5610 All-In-One InkJet Printer
Product Not Working - HP5610 ALL IN ONE
The on,copy,fax,scan and error keys blink continuoslly after power on and reset. It says reset power but there is no + key to use in reseting it.
    Novelist:
  • 106 Answers
I would like you to try other way of resetting your printer.
PERFORMING SEMI-FULL RESET
  1. Ensure that you have a two contact phone cable connected to line 1 socket of the printer and that the other end of the cable is connected to the phone jack in the wall.
  2. Perform a partial reset on the printer. To do this first remove the power supply from the back of the printer. With the power off press and hold the # and 3 keys.
  3. Plug the power back into the printer, keep holding the # and 6 keys till you see “ SEMI-FULL Reset ” displayed on the printer screen. Sometimes, the printer will just turn off, if it happen just released the two buttons then press the power ON button to turn the printer ON.
  4. After turning it ON, you will see the message "NVM SEMI-FULL" reset.
  5. If this does not resolve the issue contact HP at 1-800-474-6836
THank you so much.
adonscott
Posted on Jul 24, 2008
HP officejet 5610 All in one printer cannot print or work because power button,Alert button,copy,fax,scan button all were blinking on and off with message on screen Error:0xd05d010d please help, also reset...
Try to reset the printer:
Unplug the printer from power
Hold the # and 9 together while plugging it back
If still not working try again with a # and 3 combination
Oct 04, 2011 | HP Officejet 5610 All-In-One InkJet...
Message on HP officejet 5610 All in one Error 0xd05d010d and on button,copy,fax,scan and alert yellow light keeps blinking on and off "tried reset the power cord still givwing same problem.Please help
Hp5610 all-in-one
see it this site your problem solved
http://cluetechnologies.com/index.php?topic=688.0
Jul 03, 2010 | HP Officejet 5610 All-In-One InkJet...
When press # and 9 key while turning power on, the hp5610 should perform a full reset, however the "power on", "fax", "copy", "fax", "scan" and "!" all flash at the same time. How do I correct?
You can't. A reset is a #6. A #9 resets the NVM - the NVM is the firmware that makes the printer function. If you have reset the NVM there is no way to bring it back again unfortunately. It should only be used by HP in their repair department when they are seeking to replace the firmware components.
Feb 21, 2010 | HP Officejet 5610 All-In-One InkJet...
When I turn my hp officejet 5510 all in one ink cartridge it says the print cartridge error see the product documentation for detail copy fax, scan are all blinking.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00837918&cc=us&lc=en&dlc=en&product=311255
When lights stop blinking, you have solved the problem.
Nov 28, 2009 | HP Officejet 5510 All-In-One Thermal...
Photosmart 2610 with power on get Error 0x886a6916
0x error codes indicate that the product has an internal error. Try to reset the printer:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button
7. Reinsert the cartridges, and then close any open doors on the product
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Status light blinking red
please follow the steps given below to power cycle and reset the product.
Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product..
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
  • If the copy job is successful, you do not need to continue troubleshooting.
Reset the product Follow these steps to reset the product. Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
May 22, 2009 | HP OfficeJet 7410 All-In-One InkJet...
FAX
Where you able to scan and make copy without any problem...?
You can try a Partial reset which would reset the printer for any errors, Partial reset is: Unplug the power cord from the printers end with the power still on, and then press and hold the # and No 3 Keys in the All-In-One and insert the power cord without releasing the keys, it will display in the screen as partial reset
Aug 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
Machine Unresponsive
HP Support:
Try resetting the unit by unplugging the unit while its on, then holding on the # and 6 keys plug the power back in an continue to hold the # and 6. The printer will power itself down, the reset is complete; turn it back on using the power button and attempt a copy.
If the unit has never been able to make a copy, it is likely that unit is defective.
Mar 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Error 0xd05d010d on hp 5610
UNPLUG PRINTER FROM WALL SOCKET PRESS # AND 9 AS YOU PLUG PRINTER BACK IN TO DO A FULL RESET
Jan 18, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
150 people viewed this question
Ben Johnson
