Ptac grille Did you ever find out about the grille installation. I have the exactsame problem. It makes no sense. It doesn't seem to fit properlynever matter how you do it. Thanks! Shawn
Call up this company and they will send you a easy installation kit its about $15 and sure beats fiddling around with the grille. www.airventproducts.com
Posted on Oct 06, 2008
If you unplug an Amana PTAC unit and it freezes what could happen?
If you are not going to run the unit put a large bag over the out door section. The unit will be just fine.
Jun 08, 2017 | Heating & Cooling
1999 dodge ram 1500 truck stopped running going down the road trys to start but doesn't seems to be getting fuel
Have the fault codes read. Replace faulty items. Use only genuine items as non-genuine replacement are not always compatible with the OEM fitted CPU units. Look for a problem sensor that is not allowing the tank to vent and causing a vacuum preventing the pump from drawing fuel
Mar 28, 2013 | 1999 Dodge Ram 1500 Truck Black Grille...
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
Grill slow to start, doesn't get hot
sometimes spider webs clogs the orifaces. also check your regulator .if its not making any sound give it a light tap with wooden hammer handle sometimes the diaphram sticks
Feb 24, 2012 | Viking VGIQ5323RE1N Gas Grill
Battery doesn't fit for the push button start, what size battery do you use
1 - AAA Alkaline Battery. When installed, the Positive (+) end goes in face down. Negative (-) end should be facing you.
Hope this helps and thanks for choosing FixYa.
Jul 26, 2011 | Weber Q Grill
The Grill side on my electric cooktop doesnt seem heat up enough
I had the same problem with the 45" Jenn Air downdraft cook top. The installation of the ductwork from the stove to the outside of the house was not properly installed. The stove is appr 18' from an outside wall and the flow of air was hampered by
too great a bend in the ductwork at the point below the stove on the underside of the house and the pipe going to the outside wall. I believe that was corrected with more curve in the vent work, making for a smoother flow of air. Make sense?
Jan 07, 2010 | Jenn-Air JED8230 Electric Cooktop
Lg ptac heat pump/ac 12k btu 230v stamped allum grille installation
1. open grill from out door box.
2 fix outer box where u want.
3 put a/c inside the out box
4 make proper wiring.
on the unit
Mar 21, 2008 | Heating & Cooling
Gaggenau VR 122-612 In door Grill
The heating elements have burn out. I had the same thing happen 3 times and am now looking for replacement elements for mine--- mine was installed in 1995. Anyone know where replacement elements can be found?
BC
Oct 16, 2007 | Gaggenau VR 322-612 Indoor Grill
Heating & Cooling Logo
265 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
