Question about LG Dehumidifiers
Stopped Running - Control Panel CH 01
My dehumidifier has been working fine for the past year. It recently stopped and hs CH 01 on the control panel. The manual does not have a troubleshhoting guide with messages like this on the control panel. Do you know what this means and how to fix it? I have tried the reset button and turned it off then back again.
Thank you.
  • 1 more comment
  • janh59 Sep 07, 2008
    Same problwm CH 01 just stopped running and it will not reset
  • jlhefner Oct 24, 2008
    CH 01 APPEARS ON CONTROL PANEL DISPLAY. UNIT WILL NOT OPERATE. NO NOTATIONS/TROUBLE SHOOTING INSTRUCTIONS FOR THIS CODE. DOES ANYONE HAVE A SOLUTION?
  • marilyn7637 Nov 10, 2008
    i have the same problem what to do.
  • 4 Answers
All, I had this same problem as well. I called the LG Support Line and they told me the unit needed to be serviced. I went through the motions of getting the service providers and what have you, but I wasn't going to go through with it because the closes service provider was a 45 minute drive. I posted how disappointed I was because I had only had the unit for a year, but could not find my earlier post.
Anyay, I am glad I went through the motions, because a few days later LG called and told me they would be shipping me a refurbished replacement. Wow. That was a treat. They shipped me a refurbished unit and had me send the old one back. I did not have to pay a dime. The sent me the Fedex shipping label via email and I called Fedex and they came by and picked it up.
I cannot remember if I had registered the unit when I initially purchased it. Sometimes I won't do that because it seems only to serve as a license to sell me stuff. They took down all my contact information and sent me the unit so I don't know. I would simply encourage everyone with the CH 01 error code to give LG a call via the support number from their website at lgappliances.com. Good luck!
Posted on Sep 28, 2009
My dehumidifier has stopped running all of a sudden. it has CH on the panel..what does this mean??
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Aug 04, 2011 | Dehumidifiers
Hi, When I tried to start my dehumidifier, it won't work and indicate CH 01. The bucket is totally empty and in good place. What this CH 01 means?
Your model is no longer in manufacture or available. However, I was able to locate the Owners Manual for you. It does not list a CH 01 Error Code, but does list other reasons why your unit want turn ON.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LHD45EL&matchedModelCode=1000001989&searchEngineModelCode=LHD45EL&targetPage=support-product-profile&initialTab=documents#
In the past, I have recommended turning the Master ON/OFF Switch to OFF and unplugging the unit for 12-15 minutes. This will give the unit time to hopefully, reset itself. Then Plug the unit back in and turn the Master ON/OFF Switch to ON. Set the humidity control as you normally would. If it successfully reset itself, it should operate normally.
If you continue to have problems, contact LG Customer Support at 800-243-0000.
Hope this helped you to solve the problem.
Apr 14, 2011 | LG LHD45EL Dehumidifier
Code (CH) (01) on front panel, what does it mean?
I believe it is a water tank code. Re-seat the tank, unplug wait 15 seconds and replug the power cord and see if this resolves the error.
Background relating to other possibilities.
When the water bucket reaches its capacity, the bucket switch opens to shut off the dehumidifier. If the bucket switch fails while it is open, it will prevent the dehumidifier from running. To determine if the bucket switch is defective, use a multimeter to test it for continuity. If the bucket switch does not have continuity, replace it.
Sep 17, 2017 | LG LHD45EL Dehumidifier
Zenith ZD30 dehumidifier - 1 1/2 years old stopped working had a half bucket oc colledted water in bucket when it stopped. I checked the fuse on the circuit board and have continuity.
Unplug from wall. Take the front cover off and disconnect the 2 wires that attach to the humidity control dial. Plug back in. If it works, the problem is the humidty control dial (mine just went bad). With it unhooked, it will run constantly, but will still turn off when the bucket is full. To turn off, simply unplug.
Jun 16, 2010 | Dehumidifiers
Won't come on
Definitely check the air filter, it has a sensor and will stop working if it's dirty. Easy to clean by running water through it.
Jun 09, 2010 | Goldstar DH304 Dehumidifier
Stopped working for no apparent reason
The main control board has failed and needs to be replaced
Apr 23, 2009 | Fedders R6DH45X Dehumidifier
Take cover off. First check the fuse on the circuit board. If it's blown replace it. That should get the motor running, the motor might be or is going out. If the motor is bad you'll have to replace the motor. If the fuse is good and the motor is good, unhook the wires on circuit board that go to the humidity control switch. If the unit comes on with the humidity control switch unhooked, you'll have to replace the humidity control switch. Sears has them for about $11.50. Hope this helps.
Sep 13, 2008 | Goldstar DH304 Dehumidifier
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Feb 04, 2008 | Whirlpool AD40USR Dehumidifier
Dehumidifiers Logo
1,821 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
