SOURCE: Frost on Ice Maker shute
Dtot, does the flap shut all the way? Sounds like you are drawing moisture from the chute. The flapper should seat so that no air is being drawn in. I have seen a number of these Whirlpools where the pin and spring retainer has broken off from the dispensor housing causing this problem. They use to replace the whole freezer door because the dispensor housing is not a servicable part. They have now come out with a kit to address this problem. This is not a fun job for a first timer. You may want to contact Whirlpool and inquire about the aforementioned. If this is your case, there is a good chance they will cover it. Catriver..post back.
SOURCE: Water/freezing to ice at the bottom of the freezer MZD2766ge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all that ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youll melt everything) or by pouring hot water down the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
SOURCE: Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
SOURCE: Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
SOURCE: my ice maker quit making ice.
Hi, If your ice maker has stopped making ice then you need to check these things.
The lever that controls the ice maker has been pushed
up which turns it off. If you have a red lever, pull it down to the
wire and if you just have a wire then just pull down the wire to start
your ice maker up.
Make sure the freezer temperature is below 10 degrees
F If the freezer is too warm ice production will be poor because the
ice maker will not cycle properly.
The ice maker fill tube may have ice formed in it,
blocking it. Use a hair dryer to melt the ice. Watch out for the
plastic parts, so that you do not melt the plastic. Also check the
water inlet valve and the shut off valve, to make sure it is not
plugged with debris. The openings in those valves are very small.
Check the gears in the ice makers to see if they are
broken or stripped. Also look to see if the ice rake is broken. All
parts in the ice maker are replaceable individually, If you find broken
parts replace them.
Take care
