Question about Olevia LT32HVM 32 in. LCD Television
Olevia 27 " picture delayed
My Olevia TV is about 1 yr old. Recently when I turn it on (using the remote), there is about a 15 - 20 second delay before anything happens - Picture and audio.  The delay is new, as it has always powered up almost immediately.  Once it comes on, the picture and sound is find.  Any ideas?
  • Olevia Master
  • 5,568 Answers
Since I have noted many problems which can only be related to the power supply in this set, I'm afraid it may worsen and finally fail.
Modern power supplies are fairly complex devices (far more than a transformer and a few diodes) and are fussy about certain components (electrolytic capacitors) they require.
There was a flood of defective parts, failing because of a counterfeit electrolyte made in . . . China, of course.
There are literally millions of parts waiting to fail, some already installed, many more in the pipeline.
It will be years before they are all replaced and sorting them out is impossible since they do not externally differ from good parts.
Since they do not show up until they have been in operation for some (unknown) time, otherwise reliable manufacturers are suffering along with consumers.
Posted on Aug 02, 2008
I just purchased a Kodak Eastshare c182 and I would like to know how to take time delayed pictures.
Manual:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg01041/C182_xUG_GLB_en.pdf
Page 11
Using the self-timer
Use the self-timer when you want to be included in a picture, or to ensure a steady
Shutter button press. Place the camera on a tripod or flat surface.
1 In any picture-taking mode, press the Info button to turn on the shortcut icons.
2 Press to highlight the self-timer icon. Press to choose a setting:
10 seconds- A picture is taken after a 10-second delay (so you have time
to get into the scene).
2 seconds- A picture is taken after a 2-second delay (for a steady, shutter
release on a tripod).
2 shot- The first picture is taken after a 10-second delay. A second picture
is taken 8 seconds later.
3 Compose the scene. Press the Shutter button halfway, then completely down.
The camera takes the picture/pictures after the delay.
Use the same procedure to take a 2- or 10-second self-timer video, but press the
Shutter button completely down.
Mar 18, 2011 | Cameras
When I change the channel there is a delay before picture appears. It will say NO Signal for up to 20 seconds sometimes
Your problem is a problem generated from low signal. You will need to check your antenna (or source) for loose connections and alignment.
Jun 13, 2010 | Olevia LT27HVX 27 in. LCD Television
I have problems having the Logitech One to choose right input on my SonyKDL-32EX501. It changes between HDMI 1, Analog and AV1, and ignores other active ports. Have to use Help every time in order to...
If HELP fixes the problem, then this is a delay issue. Try increasing your TV's input and inter-device delays.
1. Click 'Settings' next to the icong for your TV in the software.
2. Select 'Adjust the delays (speed settings)'
Apr 26, 2010 | Logitech Harmony One Advanced Universal...
Using self timer on my digital camera
1 In any Still mode, tap Settings to open the Settings
panel.
2 Tap Self-Timer/Burst repeatedly, until the desired
Self-timer icon appears at the bottom of the LCD:
10 seconds—A picture is taken after a 10-second
delay (so you have time to get into the scene).
2 seconds—A picture is taken after a 2-second
delay (for a steady, auto-shutter release on a
tripod).
2 shot—The first picture is taken after a 10-second
delay. A second picture is taken 8 seconds later.
Apr 29, 2009 | Kodak EasyShare V1073 Digital Camera
Blue screen
Check the CRT.and then check if there is a loose solder on the whole board and also check the H-out..change the CRT socket which is Color White Connected to the Tube.
Nov 12, 2008 | Samsung TX-R2735 27" TV
Microphone delay for Rock Band
should be video delay settings in the game, this is a common issue with hdtv's, the issue is not that your audio is delayed but your video is delayed making illusion that your audio is off.
Aug 20, 2008 | Sony PlayStation 2 (PS2) Console
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Olevia LT32HVM 32 in. LCD Television Logo
71 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
