Question about Car Audio & Video
Car amplifiers i have a Jeep Grand Cherokee Laredo with an infinity gold system, the amplifier has recently began to go bad, i have no clue what type of amp to get to power just the 4 door speakers and 2 tweeters in the dash, any advice on what type i should get?
Are the tweeters connected to a crossover?
I'd recommend a rockford fosgate 4 channel punch series. affordable, yet the quality is superd. i had a p450.4 run infinity kappa series seps in the front and a polk audio db691 ovals at the back. wired it up. it was LOUD. and the clarity was just amazing.
Posted on Jul 27, 2008
Back Speakers don't work.
Change the radio if it looks worse than the speakers. Or, go buy some junkyard speakers and try them out. If none of this works, sell the car.
Apr 01, 2014 | 2000 Jeep Grand Cherokee
I have the infinity gold system in my 95 grand cherokee and only speakers that work is the tweeters in the dash. i just find it hard to believe that all the speakers blew and not the tweeters. does anybody...
Chances are the problem is an amplifier or the radio itself.
Usually you would use a meter to see if you have power to the speakers and to do that you would need a shop manual to get the wiring diagrams.
Feb 06, 2013 | 1995 Jeep Grand Cherokee
Where is the fuse for infinity gold amp 1996 Jeep Grand Cherokee
Not sure if it's the same but I have a 99 grand, and the fuse is in the amp under the back seat on the passengers side
Jan 26, 2012 | Infinity 475A Car Audio Amplifier
Is there an in-line amplifier for the speakers in a 96 jeep grand cherokee limited w/ infinity gold audio system
Yes, the Infinity Gold series audio systems have a separate amplifier. In my '97 the amplifier is located under the drivers side rear seat.
Note that the amplifier is set to have speaker level inputs as opposed to regular level inputs. Both the amplifier and the speakers are NOT easily mixed and matched with after market components.
Nov 13, 2009 | 1996 Jeep Grand Cherokee
Pioneer DEH-P6400MP plus a Jeep Infinity Gold 2 ohm system
yes but make sure you connect the power wire of the amplifier and buy a converter for the amplifier so you can get great sound.
Sep 20, 2009 | Pioneer DEH-P4600 CD Player
I have a 1995 Grand Jeep Cherokee Larado I'm putting in an after market stereo. It has an infinity gold system and amplifier. I can't get any sound out of it and can't figure out which wire to connect the...
a good way to find out is, if your lucky- you still have the plug connected to the wires in your dash. Buy a wiring harness from a place like Best Buy. The harness, when plugged in to your factory harness will have its blue wire in line with the factory amp wire. There also may be a Blue wire with white stripe, this also needs to be connected to the blue wire if the above doesn't work. If you dont have a factory plug anymore- bigger problem. brian.small@bobstgroup.com
Sep 05, 2009 | Car Audio & Video
Hooking up system to a factory infinity sound system in a jeep grand cherokee.
Tap into a signal wire (rear speaker wire) using a line level converter.
These convert the High level speaker wire output into low level RCA output that is accepted by your amplifier.
c5b61ef.jpg Get a good one Pacific Accessory Corporation (PAC) sni-35 is the best IMO.
The TRUNK-LOC is the SAME as the SNI-35 - but it incorporates a voltage sensing input - so you dont need to run an additional turn-on wire. The voltage is sensed through the speaker wire - and it turns on the amplifier.
Then you will need a fused power wire from the battery,
Ground to chassis, and remote turn on lead (if you use a standard line level adapter).
An amplifier installation kit will give you everything you need to add 1 amplifier (except the converter)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 22, 2009 | Diamond Audio D5-1200.1 Car Audio...
1997 Jeep Grand Cherokee Factory amplifier
I have the file on my other computer - search other bulletin boards. Check with Crutchfield help desk.
Input wires are the speaker wires from the Amp head/receiver (so you can go to a BestBuy and ask them for the speaker wire colors). Black is ground. Yellow/black is main power. Blue/white is turn on wire. If in doubt take off the door panels and look at what color wires go to the speakers.
Oct 17, 2008 | 1997 Jeep Grand Cherokee
Car Audio & Video Logo
278 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
