Question about Durabrand DUR7 Portable DVD Player
Broken cable where can we get new cable for our link to second screen
  • disiel Sep 28, 2008
    i need a cable to connect second screen to dvd player
  • 2,794 Answers
Check at Radio Shack. They should have the cable you need.
Posted on Jul 23, 2008
Cable to screen from motherboard broken want to create another one
Purchase a new cable from flea bay. That is the easiest option.
Nov 13, 2013 | Compaq Evo N610C Notebook
Green horizontal lines on display
First thing to try is another HDMI cable and see if this fixes the problem. Seen a bad cables way too many times...
Second: update your videocard to the latest drivers:
You can find the correct drivers @ AMD support. Click the link and choose the correct settings. Then click display results. Download & install.
Third thing you could try is another monitor. Even a new monitor can be broken. Not uncommon. If another monitor has a good image then return your new one and let them give you a good one
Oct 17, 2013 | Dell Computers & Internet
First you have to open the monitor casing
Secondly you Remove the keyboard and the rest of the device to be able to open the cover of the entire screen with caution cables WiFi
Thirdly Remove the screws on the sides of the screen with the caution of their small size and dimension decoder screen cable from the back carefully dismantling screen cables from the front in a small plate and went cautiously can successfully change the screen
With best wishes luck
Mar 24, 2013 | HP 530 Notebook
Randomly says 'Component' and screen goes black when watching movies.
you gave very little info to go on. are you using component connection? if so check the green connection for loose or broken cable/connector. or replace the component cable with a new one. if you are using HDMI check for loose connections or replace the HDMI cable
Jan 17, 2013 | Sharp Aquos Televison & Video
Acer Aspire One A150 : screen all dark after changing it
It is an inverter problem. Check all cable attachments first, then change out the inverter.
Feb 17, 2010 | Acer Aspire One A150-1049 Notebook
Need to replace LCD screen toshiba p105-s6024. need instructions to remove screen
First of all, I assume that your new LCD screen is compatible with theold one. Different screens require different video cables. Make sureyou new screen is compatible with your laptop.
Use the link below for more details and instructions.
Sep 26, 2009 | Toshiba Satellite P105-S6024 Notebook
Replaced the screen but there is no image coming up, just a lit up black screen.
if you could see any image from the broken lcd before changing it so your new lcd is not working or no installed right
and if not you may try the cable or the hard shock that broke your lcd effected the main board
May 06, 2009 | LG Shine CU720 Cellular Phone
Broken top screen (original DS)
Replying to the first post:
If you have broken the ribbon cable, which is highly likely if you have broken the hinge, then the DS will not work. It does not turn on unless there is a connection to both screens. You will need to buy a new ribbon cable for it:
A useful site I found is:
Once you replace this then it should work for you.
Repling to th second post:
I would recommend buying a new case for it at least because the ribbon cable will break if left broken due to the strain on it.
The more expensive but easier option is to buy a new one.
Hope this helps,
Jun 16, 2008 | Nintendo DS Console
if you can get hold of a second Dell Lappy (same model) which is broken (not broken screen) you can swap the broken screen for the good one. It means opening the laptop, but due to the smashed screen the warranty is invalid anyway. There is usually 1 or 2 cables coming from the screen 1 for signal and 1 for power. you can explore the broken lappy to see how the screen connects,
Oct 08, 2007 | Dell Latitude C640 Notebook
Durabrand DUR7 Portable DVD Player Logo
18 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
