Question about Canon Office Equipment & Supplies
Where do i put paper into printer? - Canon Office Equipment & Supplies
    Sergeant:
    Champion:
  • 246 Answers
Normaly their is a sign like a paper that is the plase that paper are put. or try to see from the manual
Posted on Jul 22, 2008
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
Tip
PROBLEM - OUT OF PAPER
If many people are waiting for printouts, and nothing is actually being printed, the printer may be out of paper; the printer will indicate this on its display. To load paper into the N4525 printer, simply pull out the tray #1 or #2 located at the bottom of the printer in the front, and put the paper in the bin. Put the tray back into the printer. To load paper into the N24 printer, locate the tray in the front of the printer. <br />Pull the tray out, and locate the bin indicated by the large arrow in the lower left-hand corner. This is the side where you put the paper. Then, push tray 4 back in to the printer<br />.Make sure you put the paper on the correct side of the tray. This is the most common error. There are usually diagrams on the inside of the trays indicating how to put in the paper.
on Jan 06, 2011 | Office Equipment & Supplies
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
I put paper in align the guide, click on print. It doesn't print. It says it is unable to detect paper width.
Restart your printer,put 8.5X11 papers in th paper tray.Align the gray coloured paper tray to the edge of the paper.Place any paper on the scanner glass of the printer and press copy on the printer.You will get a copy from the printer. Keep posting me ...
Dec 14, 2009 | Kodak ESP 5 Printer
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
As soon as I put paper in my printer, it takes the paper slower and then states "Paper Jam"
Run maintance and do a cleaning.. fluff the paper and make sure your not putting to much paper in the printer.
Sep 26, 2009 | Canon PIXMA MP470 All-in-One Printer
I put a hard paper in the printer then it will not come out
ok power off then remove cartridge and then refix it.
also put tray in excat osition.
Nov 15, 2008 | Brother DCP 115C All-In-One InkJet Printer
No paper fed
Pull the paper tray out, then turn the printer on it's side. There is a mechanisim that has some rubber band type grips that pick the paper up. Pull them off, turn them inside out and put them back on. Give it another try.
Jul 23, 2008 | Lexmark E234 Laser Printer
Paper feed
Make sure you fan the paper before putting it in. 20 sheets is usually about right for these printers.
If you put labels in the printer. Only put a few sheet in at a time and put paper stock below them.
May 22, 2008 | HP DeskJet 820Cse Printer
32 people viewed this question
old marine
old marine
