Panasonic inverter H11 fault
Panasonic airconditioner H11 fault
  • Anonymous Dec 15, 2008
    I have the same problem and I don't know what's happened.....
    Do you have the solution?
    Let me know please in case.....
    Thank you
3 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: remote doesn't work on air con
Should be current detect pcb faulty, or compressor drawing too much current.
I don't have your model a/c, but panasonic fault codes stay pretty much the same
Normally panasonics have this info on the inside of the access panel.
Plus fault codes from the indoor unit make it easier to look up.
if the compressor is running, check the amps and refrig pressures.
Posted on Sep 19, 2009
hvac1960
  • 2133 Answers
SOURCE: my panasonic inverter airconditioner is
Battery low in remote? or Thermostat? Please confirm.
Posted on Dec 30, 2010
HAVE A PANASONIC MICROWAVE WITH A H98 CODE THAT ISN'T WORKING. IS WORTH TRYING TO FIX?
That fault is the inverter. It has failed. Only Authorised Panasonic suitably trained engineers should attempt repair. All they will do is replace the inverter and probably magnetron as that may have been the cause.
Oct 22, 2017 | Panasonic Microwave Ovens
Accent model ADC 27E1. Why is it displaying E C fault?
FAQs and Troubleshooting - Actron Air
www.actronair.com.au/service-and-warranty/faqs-and-troubleshooting
The air conditioner is not running at all and no control lights are on. (If there are no ...Air conditioner regularly cuts out on a circuit breaker trip or error code ...
Air conditioning (Accent Air control panel) is - Fixya
www.fixya.com/support/t3343544-air_conditioning_accent_air_control
Nov 3, 2009 - Air conditioning (Accent Air control panel) is displaying EC - what ... Panasonic mini split air conditioner css9nkua error code h99 what does it mean ...ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL .
Dec 05, 2015 | Heating & Cooling
Panasonic power light flashing air not cold blowing
hi there you need to see where you bhave a gas leak thats all the flashing light indicates that your gas pressure is to low to activate your compressor
Dec 09, 2013 | Panasonic Heating & Cooling
Panasonic inverter 900w microwave fault code h97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Thin coloured lines running down center of tv. Panasonic Viera.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP TO SOLVE THE PROBLEM.....
Aug 07, 2011 | Panasonic Televison & Video
Ive got a line down the left hand side of the screen when the tv is turned on the model number is panasonic viera tx-p42v20b
HI,
GOOD LUCK IN RECTIFYING THE FAULT, THANKS
May 13, 2011 | Panasonic Televison & Video
Remote doesn't work on air con
Sep 19, 2009 | Heating & Cooling
My panasonic inverter microwave gets a fault code H98 and stopes working.
Nov 26, 2008 | Panasonic Microwave Ovens
Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
Apr 19, 2008 | Microwave Ovens
Heating & Cooling Logo
651 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
