Question about Lexmark Office Equipment & Supplies
Printer new cartidges inserted now wont print saying there is no ink we have tryed the instruction please help.
Printer not working p6250
    Sergeant:
    Champion:
  • 246 Answers
You have to check that your new cartidres are in correct model .
Posted on Jul 22, 2008
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
New cartidge had been bought but after installation of the cartidge i tried printing a page to just check but to my astonishment the page came blank. please help me out !
Did you remove the small piece of "sealing" tape before you inserted the cartridge?
Try running a few "PRINT HEAD CLEANING" cycles, to unclog any ink-jets.
Jan 27, 2011 | Office Equipment & Supplies
Replaced the ink in stylus sx 125 with genuine epson ink ... and now wont print at all
Perhaps try accessing the menu using the press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge carriage will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then pull out the ink by holding with thumb and first finger and rotating towards you. insert the ink again by pushing in and rotating away from you. close grey cover. now confirm ink replaced as per screen prompt. the machine will run the ink to the print head, takes a minute. then turn off and on and it 'should' work.
Jan 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Changed out black ink screen says insert
It will be a hardware printing problem mostly. Try cleaning the parts with alcogol or/and elastic rubber. Also try to increase the force of contact with a sticky tape or like that.
Aug 09, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Printer wont print after ink cartridge change
Hi pater_g:
Have you tried to reinstall the old cartidge to see if it would give a different problem ( light print ect.) if not try that. If the problem stays and you just can't communicate with the printer try rebooting you computer or go to www.hp.com/support to download a new print driver. I hope this helps you.
Apr 17, 2009 | HP LaserJet 1320n Printer
Printer wont show printer cartidges are full
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
Apr 07, 2009 | Lexmark X2500 All-In-One Printer
Lexmark P6250 black ink cartridge won t print
If you have thoroughly cleaned down in print cartidge area, and printhead, with no ink coming away, remove cartridge. Repeat manual clean, use a baby wipe and wipe gold head that ink comes out of as well (if your cartridge has this. Replace. Reset ink levels in main profile page of printer interafce. Try again. If no go, try turning printer off, unplugging, replugging after a while, turning on. Retry print job. Make sure no print jobs are queued up by cancellin all jobs before you try and print again. If nothing else works i would buy a new cartridge and hope you have receipt as it may be a dud. This can happen. I have had a few over the years.
Sep 01, 2007 | Lexmark P6250 All-In-One InkJet Photo...
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
