My pc only boots in safe mode, not normal mode. How do I fix this?
  • Steven Jurman Jul 22, 2008
    Did that but it didn't work.
  • Anonymous Sep 04, 2008
    I have started in safe mode then restarted. It goes to the windows XP page then goes black. Any ideas?
  • 84 Answers
After booting the safe mode, try to restart the PC to run in the normal mode
Posted on Jul 22, 2008
My lg70 321 is stuck in safe mode ,i cant get the key board up on the screen and i tryed a reset and it didnt work , .it allso says settings has stoped what do i do to fix this?
Hi Jeannette,
Computer boots into safe mode when there is too much damage in the normal mode to be fixed, this is a special mode designed for technicians to fix internal software issues.
you can use msconfig to try to boot to normal mode, but that might put the computer in a NO BOOT LOOP in which case you will loose all the data on the computer.
i suggest calling an expert right away. call 1-877-805-1027 for expert assistance.
Aug 15, 2015 | Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Asus aspire laptop has black screen w 2 windows 1 has @ top says administrator:cmd.exe the other says safe mode in all corners how can i fix this
Your computer has booted into Safe Mode. A simple restart should fix and boot it back to normal. If it boots back into Safe Mode, Shut it down, then turn it back on while holding the Escape key. On the screen that comes up use the arrow keys to select Normal Startup, and press Enter.
Mar 23, 2011 | ASUS Computers & Internet
We have desktop xp and it is running on safemode how do we take this off
You can't take off Safe Mode, it's there for your protection. However, if you want to boot into Normal Mode, shut down the computer. When you hear the computer beep, start tapping F8 on your keyboard. Keep tapping it until you reach the Advanced Options menu. Once you've reached this, just select "Start Windows Normally".
Now it will boot you into Windows on Normal Mode, not Safe Mode.
Jan 01, 2011 | Computers & Internet
My asus Eee 1005 wont boot up unless i go to safe mode with networking, how do i fix this so I can boot up normally without using safe mode?
If it is booting up in safe mode and not booting up normally then it could be a driver fault or some sort of spyware virus.
Try using system restore in safe mode to restore the laptop to a time when it was working fine.
goto start bar, click on run and type msconfig, in here you can choose anystart up programs or services you dont need or use and stop them from starting, make sure you are positive you are stoping programs that you know are on your mechine.
Dont restart yet goto my computer c:drive, goto the windows folder and find a folder called prefetch open this folder and delete all of it contents, once done close out of all windows and restart the pc in normal mode hopfully the problem will be solved.
hope this helps and please post back what happens.
Aug 12, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Actually when i log on the computer then show the normal mode,safe mode etc.But when we press normal mode then donot open operating system. so whats the problem?
i think your os files may have been corrupted. first try to boot in safe mode. if it works then reboot and the next time if menu comes select normal mode.
normaly if safe mode boot succeed, then in next boot it will not ask for anything, the windows boots normaly.
Feb 19, 2010 | Microsoft Windows XP Professional for PC
HOW DO I TAKE MY HP PAVILION DV6000 OFF OF SAFE MODE. BECAUSE THE PC CUT OFF CAUSE OF LOW BATTERY. I JUST WANT PC TO BE BACK IN REGULAR MODE NOT SAFE MODE
You should just have to shut it down in safe mode and reboot. And it should come up in normal mode. You can try hitting F8 when you turn it on until you get the boot menu and then select boot in normal mode.
If it keep wanting to go into safe mode it may need to reboto a few times to clear out something before it behaves but it should boot into normal mode on its own.
Oct 24, 2009 | HP Pavilion dv6000z Notebook
Service Pack 3 upgrade fro, Sp2 installed will not reboot in normal mode OK in safe mode
since are able to boot from safe mode then try system restoreto the date it was working
May 07, 2009 | Computers & Internet
Can't get out of safe mode
While booting ur system press F8 initially when system turned on you will get booting options .Select Normal and Enter you can able to boot in normal mode.
Oct 26, 2008 | Microsoft Windows 2000 Professional for PC
Computers & Internet Logo
David Payne
David Payne
