Question about Honeywell Heating & Cooling
Honeywell logic module troubleshooting w7212a1009
Older pictures of honey wells
Paula, remove the cover of the thermostat and look for a model number. The actual thermostat may have to be removed from the sub-base to find it. There may be either a long line of pins on the sub base that matches up with holes on the back of the thermostat when you re attach it....or there may simply be a 3" long ribbon connector that makes the connection.
Once you have the correct model number call Honeywell Customer Service at 1 877 841 2840 and work your way through the menu until you get to 'if you a homeowner push this number'. Once in touch with a live troubleshooter, they should be able to assist you in programming. You should know what kind of system you have, gas, electric or heat pump heat with central air.
You MUST have the correct model number BEFORE you call.
Nov 10, 2015 | Honeywell Programmable Thermostat Heater
Automatic pilot light wont light on a honeywell furnace
Honeywell is a controls company and makes a variety of auto-pilots. If this is a no spark problem,does the lead from the igniter go to a big PC board or a module. If a module, check voltage to the spark module or thermostat voltage to the ignition module. If it comes from a large board, the board may be bad. I'll need more Info. if this does not cover it for you.
Nov 18, 2013 | Honeywell Power Humidifier: Furnace...
Pr sw failed to close
Troubleshoot by type of gas control valve
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Repeated 3 flash on power vented honeywell gas control thermostat means system in lockout.
Repeated 3 flash on atmospheric-vent Honeywell gas control valve means temperature sensor failure.
Take apart gas control, and buy temperature sensor if sold separately at AO Smith dealer.
http://waterheatertimer.org/How-to-replace-Honeywell-gas-control-valve.html
Add a comment with more information
Mar 23, 2013 | Rheem 40 Gallon FVR NATGAS Low WATER...
Troubleshoot honeywell hz311
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Oct 30, 2010 | Heating & Cooling
Honeywell s861ou 3009 intermittent pilot module, i just installed this control on my furnace. I have one wire left from my old johnson control. this wire either goes to the draft fan or the burnham logic...
What is the wire on the old control.....what terminal is it on??....When replacing old controls the new ones often have different terminals and sometimes incorporate some terminal internally etc....the Wiring Diagram included should be followed exact....if it's working fineit's likely ok....if you have any doubt have it looked at by an expert
Oct 21, 2009 | Honeywell Electronic Programmable...
How do you set logic six alarm keys from alarm keypad
You should go to the this link and follow the process.
http://www.security.honeywell.com/uk/intruder/documents/Logic%206.pdf
If it doesn't work then let me know.
Sep 14, 2009 | Computers & Internet
Thermostat is in the locking position, need to unlock
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
Please rate my answer!
Mar 04, 2009 | Honeywell Electronic Programmable...
Thermostat
That thermostat must be used with a THM5421C1008 Equipment Interface Module. The thermostat communicates with the module and the module is connected to the HVAC components.
Feb 08, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
228 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
