Question about Casio DR-T220 Calculator
Casio DR-T220 I loaded the paper on this calculator and closed it on the paper and it feeds but nothing prints. it apepars to be a simple load the paper in and close the lid on it according to the instructions on the machine. Can you help?
  • 3 more comments
  • maria325 Aug 06, 2008
    Lost the manual...can't seem to figure out how to feed paper into calculator. Also, where is the ink cartridge located?
  • Anonymous Feb 04, 2009
    When I load paper it does not print.Mary
  • Anonymous Apr 25, 2009
    οδηγι?­ς χρ?®σε?Žσ στα ελληνικ?¬ (δεν ?­χει)
  • Anonymous Mar 12, 2014
    install paper in DR-T220
  • Anonymous Mar 24, 2014
    I have two of these calculators. One has feed paper out on its own for a while. The second one is just starting to feed the paper out on its own. Once I had to un-plug the older calculator to get it to stop, even though it was not on.
Turns out the incorrect type of paper was being used. The paper needed is the paper that is sensitive to pressure and this paper was not.
Posted on Jul 22, 2008
How do I change prices in casio pcr t220
Go to Casio Support Webpage and download the Owners Manual.
Here: http://www.casio4business.com/sa/support/downloads/downloads_manuals.html
Oct 31, 2013 | Casio DR-T220 DR-T220 One-Color Thermal...
How to load paper in casio calculator HR-100TM
Put the roll on the arms "like a toilet paper roll on the extender", and pull it under. There is a slot, slip the paper into this slot, and press FEED until the paper reaches the ink.
Sep 05, 2011 | Casio HR-100TEPlus Calculator
I have a borrowed Casio FR 105S printing calculator. How do I load the paper?
Make sure the paper has a straight clean edge. Feed the paper into the slot in the back - make sure the paper is straight. Paper will go in about 1/4 inch. Push the feed button and the paper should feed through the printer.
Feb 05, 2010 | Casio HR-8TMPlus Calculator
I replaced the roll of paper and now it will not
The Casio DR-T220 does not use regular adding machine tape, it requires a thermal tape since it is a thermal printer. There is no ink or ink ribbon in this caculator, it is heat activated and it is the special paper that make the numbers appear. Thermal tape is available at all office supply stores.
Oct 05, 2009 | Casio DR-T220 Calculator
I feel like a ****** but I can not figure out how to feed a new roll of calculator tape through the DR-T220 calculator. I see the picture inside but it doesn't help.
Put the roll in and feed the loose end up and actually all you need to do is put it between the two pieces of the hinge top. it is a thermal printer so it does not need to be fed like a regular calculator...it took me a few tries before I figured it out.
Sep 15, 2009 | Casio DR-T220 Calculator
Reloading tape roll on a Casio DR-T120
place the paper sticking out of the top, then close the cover. it will start working; good luck
Jun 02, 2009 | Casio DR-T120 Calculator
Place the tape between the two posts; then put back portion of cover down followed by the removal front portion - press feed button and it should feed. Remember it will only print on thermal paper ----
Dec 08, 2008 | Casio DR-T120 Calculator
HOW TO LOAD THERMAL PAPER IN DR-T120 CALCULATOR
Simply place the paper between the plastic posts. Put top portion down; feed paper up slightly - put smaller front plate back in place and press feed button.
Dec 02, 2008 | Casio DR-T120 Calculator
Printer Paper
NOT A SLOT TO FEED IT SPECIFALLY
CLOSE THE COVER TILL IT FEEDS OUT
Oct 23, 2008 | Casio DR-T120 Calculator
Printing problem
Try resetting the calculator. There should be a reset button on the underside of the machine. Press it with a pen and that should clear the E that is on your display.
Mar 18, 2007 | Casio DR-T220 Calculator
Casio DR-T220 Calculator Logo
782 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
