Question about HP Office Equipment & Supplies
Printer is the HP PSc 1600 all in one series. When printing sheet comes out blank. Not able to remove any cartridges as they are all on the left side and do not appear to move to the print carriage. There appears to be ink lying in the print carrigage. Please advise
    Sergeant:
    Champion:
  • 246 Answers
Try to remove the printer cover and look at the crtiridges.
i think the cartridges are get dry .
Posted on Jul 22, 2008
HP LJ p2015 How do you replaced the feed roller on the 250 sheet tray? It is not in the service manual?
HP LaserJet P2015 Series Printer - Replace the pickup roller (tray 1)
  1. Unplug the power cord from the printer, and allow the printer to cool.
  2. Press the print-cartridge-door button to open the print-cartridge door.
  3. Remove the print cartridge.
    After removing the print cartridge, only handle it on the ends.
  4. Grasping the pickup-roller cover with thumb and forefinger, squeeze the left side of the pickup-roller cover to release the left retaining tab, and then slide the cover to the left and up.
    Failure to slide the cover to the left when removing it can cause the right retaining tab to break.
  5. Press the two black retaining tabs outward until the pickup roller is released from its seat.
  6. Remove the old pickup roller from the printer.
  7. Line up the black retaining tabs in the printer with the grooves in the new pickup roller, and then press the pickup roller into the pickup-roller seat until the retaining tabs click.
    Do not touch the pickup-roller pad.
  8. Grasping the pickup-roller cover with thumb and forefinger, insert the pickup-roller cover's right retaining tab into the retaining slot.
  9. Squeeze the left side of the pickup-roller cover and insert the left retaining tab in the retaining slot.
  10. Close the print-cartridge door.
  11. Plug the printer in.
Jan 29, 2014 | HP LaserJet P2015 Printer
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Print cartridge will not align
This could be an issue from remanufacturing. Try a new cartridge from HP.
Many manufacturers have hardware in the cartridge and the printer that tell the printer "new cartridge". When a cartridge is refilled, you can have that giving a "bad" message.
I wish that I could be of more help.
Feb 18, 2010 | HP PSC 2110 Color Printer
My psc 2210xi sends out several blank sheets prior to printed sheets when I'm printing something from the web. Sometimes, it never prints from the web . . . just shoots out 4 blank sheets. Thx.
u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can see there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next
3.select the port usb virtual 001 for usb connection and select lpt 1 for wireless, click on next
4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer [it is a generic driver fot hp's printer]
6.click next use this printer as a default one
7.it will give u an option to print a test page
8.click on "no" and hit next
9.now try to print and check
Nov 09, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp2210 message ''press enter to align cartridges'',
from user manual::
To align newly installed print cartridges
1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
The HP All-in-One prints a print cartridge alignment sheet.
NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge.
Contact HP Support. Go to www.hp.com/support. ....
2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left.
3. Press the Scan button.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet
Score the solution and download the manual if you need it
Mar 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
I have an HP printer scanner 1310 series. Have trouble with printing. It will run about 3 blank pages through before it will print. Then it will run a page part way through so have to open back to get it...
Hi Audrey-
There are many things that will effect how your printer handles paper. The most overlooked being the size of the document or image to be printed. If the image or text bleeds over the edges (left, right, top, bottom) of the document, several sheets can be ejected before the "visible" printing takes place. Often those first few pages look blank, but actually are the outer edges of your picture or text. If you are printing a large picture or large text document, this may be your situation. Try printing a document with just a few words on it (like a small email) as a test.
The second most common culprit is dusty, dirty feed rollers in the printer. Consult your HP 1310 series manual for instructions on cleaning the feed rollers, or consult this general cleaning article on HP.com. HP PSC 1310 All-in-One Printer series cleaning
The type of paper can also effect how many sheets are pulled into the rollers. Is the paper new?, Thick?, Very thin?, or is it the same ol' printer paper you've always used? Either way, remove the stack of paper from the feed tray, "fluff" it by fanning it (like flipping through a book very quickly, or the way Superman counts a stack of money!) and replace. Print a test page.
Let me know if this helps!
Dec 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 2210 print cartridge won't align
Press and hold the Setup button.
Press the Options button. The printer should be ready to print.
Nov 24, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
46 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
