Question about D-Link DSL-G604T Wireless Router
Router's power light is flashing
When i connect myrouter to elecricity thepower light is flashing and not working. Could you please tell me what happen?
Just Reset your router for 20 secs..... and set it up again...
Posted on Aug 03, 2008
When I first started using this modem, it worked great and easily worked well with my Belkin router. One day when I came home, the modem was only flashing the "power" light was flashing and I had...
Flashing power light on Router is sign of hardware failure As mentioned, you have already reset the router
You can try to hard reset the router one more time
Follow this procedure
1. Press the reset button with some paper clip 2. Wait for 10 Secs 3. Turn of Power to the router (While Reset button is still pressed) 4. Wait for 10 secs 5. Power on router 6. Wait for 10 secs and then release the Reset button
While doing this make sure reset button is pressed continuously start from Step 1 - 6
Check if Power light still blinks
If No - you can setup router like before and it will work If yes - Buy a new router or get it replaced if under warranty
Jun 29, 2011 | Arris SURFboard SB5101 Cable Modem
I have a netgear range max, it has been working fine. Just last night nothing wireless in my house works. Cable modem works. Power light on netgear box is green. "i" icon is flashing green,...
You need to reset and reconfigure router
please follow the steps to reconfigure router
RESET THE ROUTER:
1. Make sure router is connected to power supply and is on while you perform the task below. At the rear panel of the router, near the antenna, there is a very small round pinhole that contains the reset button.
2. Using a pen/pencil/paper clip, hold the reset button for 60 sec. so that the test light starts flashing.
3. After few seconds when the test light stops flashing. Turn off the router and turn it back on after a couple of minutes.
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Regards,
Prakash
Apr 08, 2011 | NetGear WGT624 Wireless Router
I am trying to connect myrouter back up i lost the disk so I trying to go the computer route for help on this linksys router.
You can go to Linksys and get the setup info. Or if you don't know how, write back with your router model number and I can find it for you.
Thanks
Dec 23, 2010 | Computers & Internet
The wireless light on the router is not lite up and won't connect to my wreless printer, in witch it use to work. i have tried to reset the router and unplug from the moderm, nothing is working. please...
Turn everything off, modem, router and computer.
Turn on the modem first and wait for a solid data/connect light.
Turn on the router, give it two minutes.
Still if problem presists you need to reset the router ..
How to reset::
Push and release the “Reset” button.
The lights on the Router will momentarily flash.
The “Power/Ready” light will begin to blink. When the “Power/Ready” light becomes solid again, the reset is complete
Jun 03, 2010 | Belkin F5D8236-4 Router
Attempting to instal router. orange symbol above
Follow the below steps to reset and reconfigure the router: RESET:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. and hold it down for 30 seconds. After 30 seconds, please release the button and power off the device for 5 seconds.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router(isolated port).  2. Connect the computer to the router using any one of the 4 available ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEEN THE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable).  3. Power off the modem and the router after making the connections.  4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser(Internet Explorer or Mozilla Firefox).  2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.  3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).   4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.  5. Click Apply.  6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
Hope this helps.
Jan 27, 2010 | NetGear WGR614 Wireless Router
New router as of today Belkin F5d8236-4, wont connect
You will need to configure the router manually
Tell me the name of your internet service Provider ??
Dec 31, 2009 | Belkin F5D8236-4 Router
My Computer is telling me thier is a problem with my connection from the Router to the Internet.
Follow the steps:-
1)Check the light status on the router do we have all the lights working/flashing properly.
2)If Yes then try a different computer may be the problem can be with the computer itself.
3)If No then turn the computer off and then take the power cable out from the router and wait for a min and then plug the power back to the router and wait till all the lights comes back and then re-start the pc , it may work else reset the router and re-configure it.
Nov 24, 2009 | Computers & Internet
When power switch is turned on the Power light is rapidly flashing & the 4 Ethernet lights are flashing. The box is Actiontec GT704wg
I do not have a solution to the problem. However, I am having the same problem. This morning the Actiontec GT704WG power and ethernet lights were rapidly flashing. The modem was non-functional. I could not even connect to the modem through the browser to see if I could find a problem.
The problem lasted a couple of hours. Then all of a sudden the modem started working again. I won't be able to tell if the problem recurs until I restart the modem. And if the problem does occur again, I won't be able to connect to the internet.
Oct 08, 2009 | Actiontec GT704WG Wireless Router...
Dell Wireless 2350 Router
I can definitely help you on this, however, this would require us follow a few troubleshooting steps which cannot be dictated here. So, I would request you to initiate a chat session with me from the fixya homepage and we would carry on from there. Cheers
May 15, 2007 | Dell Wireless 2350 Router
D-Link DSL-G604T Wireless Router Logo
836 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
