Question about Pioneer VSX-1015TXK Receiver
My Pioneer SA-1510 Won't put out any sound. I was wondering what the most common reason would be for this to happen. I was thinking mabe there is a bad node?
I had the same problem only mine was VERY frequent (about twice/hour). I finally fixed it by taking off the cover and removing the MUTING button which I never used anyway. Remove the button that sticks through the front panel only - no wiring. The MUTING button is between the balance and volume controls. This reduced the problem from twice/hour to about once/year (we have it on severaly hours every day).
Posted on Dec 02, 2008
Mine sometimes cuts when i am in the middle of listning to music .  i have discoverd that hitting it below the meter equilizer clicks it back on......  or... you dont have the plugs that go into the adapter socket.
Posted on Aug 26, 2008
How do I fix my problem I m having with my pioneer sa-1510 amplifier
You simply have a bad solder joint somewhere. A visual examination of the solder joints should show you the problem.
Mar 03, 2016 | Pioneer Audio Players & Recorders
Where can i get a free download for a pioneer sa-1510 amp
If you are referring to a user manual U can try the manufacturer web site.
Bypass voltage switch
You'll have to be more specific, as I have no idea as to what you're you are describing. The only voltage "switch" would be the power switch, which now a days, is only a momentary contact switch input to the microprocessor(computer inside) I would suggest you contact me directly on my website, audioserviceclinic.com, as this type of question that is too detailed for an answer on FixYa. Please contact me through the Contact Page on my site. Thank you.
Jun 12, 2012 | Pioneer Audio Players & Recorders
My Pioneer GM-X334 needs a fuse I am wondering what fuse to put into it?
The best thing to do is bring it to your local car audio shop. It should be relatively inexpensive and you won't have to stress. ALSO, look online for the shops... Do some research if you'd like to make sure they are honest and have great customer relationships...
Aug 29, 2011 | Pioneer GM-X334 Car Audio Amplifier
My Panasonic SA-PT875 surround sound system won't
Hi, I have the same issue ! ... Can you let me know if you fixed it please.
Regards Brad
Aug 16, 2011 | Panasonic Audio Players & Recorders
My pioneer car stereo DEH-P77MP won't play cd's anymore. the radio still works, but on the screen it says cd error AO or A0. i was wondering what problem this code relates to? hope you can help,...
This is a common error with these units when they get dusty from putting dirty disks inside the drive. Just go to your local staples and or walmart and get a 5 dollar disk player cleaning kit. It looks like a plain cd but has small fibers that come out of the bottom of the disc that clean the laser as it spins and tries to read it.
May 09, 2011 | Pioneer DEH-P77MP CD Player
Radio cuts out but can not hear caller or them hear me
it sounds like a fault with the mic, mabe it is trapped or not plugged in properly. get your engineer back to sort it, they should have fully tested it before leaving.
Nov 19, 2009 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Pioneer SA 9800 Ampliffier Output transistor going off frequently
I assume these are the complimentary pair that drive the speakers. On one of the speaker. You know I think you have a short in the speaker that it drives. Speaker can fuction even if there was a problem with it. I think what happened is when the original transistors shorted out it overloaded the speaker, but not to a point where it is burnt. There is nothing that can overload a power transistor except the speakers, I design a lot of amplifiers, the base input can overload it if you put dc in there, but that would make a the sound all distorted, I assume the sound seem fine. Solution is try connecting a known good speaker and I bet it wont burn out anymore. Even if the speaker look fine don't trust it.
Jun 30, 2009 | Lasonic TRC-931 Cassette Boombox
I have a Pioneer SA 1050. All the lights come on
check your speaker selector switch to see if its on the correct setting ie; speakers one ( not speakers 2 ) also check your speaker cables by reversing them, ie; put right speaker cable into left channel and vice versa with the left etc? check also to see if your amp is set to headphone output by mistake in which case no sound will come out until you select the speakers instead? good luck.
Jun 24, 2009 | Pioneer Audio Players & Recorders
Pioneer VSX-1015TXK Receiver Logo
942 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
