Televison & Video Logo
Anonymous Posted on Feb 06, 2011
I bought the DTA800B1 converter box and I tried to program it to my tv but none of the codes you have listed work on my tv I have a emerson EWF2004A. Any more I could try???
Anonymous
Level 2:
Scholar:
  • Expert 64 Answers
  • Posted on Feb 06, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
64
Questions
0
Helped
45647
Points
170
Depending on what model rca remote control you have. Here is a link once you find the remote control model number - http://rcaaudiovideo.com/remotecodefinder/?sku=&productType=TV
  • Anonymous Feb 10, 2011
    Sorry I just realized what you were asking. If none of the codes work, the manual says to use the remote that came with the tv, its not a great solution but if all else fails. link to manualhttp://dtvconverterboxes.blogspot.com/20...
I need the codes for sanyo tv to program dta800b1 digital tv converter box remote model is rc27a
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
I need program code for vizion tv to program my DTA800B1 remote
0029,0027. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electrohelponline.blogspot.com/
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
Have an rca digital converter box model dta800b1 and a phillips universal remote can i program it so my box get the channels
Find the user guide for your universal remote and use the RCA cable tv/satellite codes, and one should work for your RCA DTA800B1 converter box. My Sharp Aquos remote liked the RCA satellite code.
Tv remote codes
I own a One-for-All universal remote, and my booklet says the setup code for an Emerson TV (without a built-in DVD or VCR) is one of the following numbers: 0154, 0171, 0178, 0180, 0236, 0451, 0463, 1944, 1963. I can not guarantee these numbers will work with your remote, but it is worth a try.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
