Hello
I cannot help you but I wonder if you can help me I have a Sonar DX card but capacitor CE 34 dropped off the PCB and I need to find a replacement to attempt a repair. I need to know any info on size value and voltage rating etc to find a part.
Thanks John
Are these the drivers you tried?
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Hardware&p=Asus%20Xonar%20DX%20Sound%20Card&v=ASUS&uid=XONARDX&pf=0&pi=0&s=xonar%20ds&os=64-bit
Is there a chance that the windows 7 will recognize the soundcard and load its own drivers for it, they might work better?
I have seen Videocard drivers mess with soundcard drivers and vise versa (with Vista, XP and earlier)
Also if there is an onboard audio chip you'll want to disable it in the bios or at least in the device manager.
let me know if this helps or not
Thankyou
SOURCE: Hi,. I own Asus Xonar DX two years ago without
if your computer came with a motherboard disc the sound drivers could be on it have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
hope this helps
