Question about Kenwood KDC-MP528 CD Player
Power to stereo none to unit
We bought a Kenwood KDC-MP528 on ebay without the face plate cause we had the face plate but our stereo got stolen. Anyways, there is power to the stereo cause we can see the red light but our face plate isnt lighting up. Do we maybe have it wired wrong and/or would our face plate work on any stereo as long as it was that particular model?
    President:
  • 624 Answers
There is a ribbon cable that goes from the display to the main board of the radio that may be bad, if you have everything connected properly and all you get is the red led, this is a possibility. No way for anybody to know if you have it wired wrong if they can not look at it themself.
The red wire is for power when the key is on, the yellow wire should get power all the time, the black wire is ground.
If you have those correct, the radio should at least turn on. If you have these right, you may need a new ribbon cable. The connector that interfaces with the detachable face must also be taken off the old ribbon cable and put on the new one, or get a new connector and just replace it. The ribbon cable does not come with that connector. It is soldered on the ribbon cable, so if you are not very good with a soldering iron, you should have a service center do it for you.
Let me know if you want the part number for the ribbon cable and/or connector, I can get those for you.
I can not guarantee that the ribbon cable is the problem, or that it is the only problem, but it is the most likely problem with that model number of Kenwood. I have repaired many of them, so I have a good idea what causes most of the problems, but I have seen times when the usual suspect is not the problem and something else like the LCD in the face is bad, or the IC that controls the display is bad. Even a voltage regulator on the main board of the radio can be at fault as well. There are probably about 10 different things that can cause that one problem, having an experienced technician is always the best way to determan the problem with certainty.
Let me know if I can be any more help for you.
Dave
Posted on Jul 25, 2008
I have no display on my kenwood radio, but it will play the radio fm stations. the cd door will not open either.
Use a small pick tool (like dentists use) to reshape those brass connectors on the back of the face plate. If this model has a ribbon instead of brass connectors it's junk. Make sure where the connectors meet the head unit is clean.
Sep 29, 2010 | Kenwood KDC-MP528 CD Player
I have a Kenwood KDC 135 car stereo wont un mute.
behind the face plate there is a little recessed reset button. push it using the tip of a pen or similar. that will fully reset the radio to like it was when you bought it.
Some times head units hicup. this is how you reset it. In most error cases this solves the problem.
Dec 15, 2009 | Kenwood KDC-135 CD Player
Kenwood KDC-MP828: Security Code?
Get your money back. It is probably stolen.
Sep 14, 2009 | Kenwood KDC-MP528 CD Player
Face wont open
if you have already tried hitting the reset button you should first remove the faceplate and check the contacts on the main unit and the back of the faceplate. if they are dirty clean them (with power off) with contact cleaner or a small eraser. if your lucky that will fix the problem but most likely you have a bad ribbon cable. this cable attaches the faceplate contacts to the main unit and flexes as the face tilts. after time these cables get small cracks that may not be visible. you can usualy buy the part from a place like pacparts.com and replace it to solve your problem.
Dec 16, 2008 | Kenwood KDC-MP528 CD Player
Face plate on KDC-MP528 kenwood deck wont open
if you have checked all of your wiring and fuses and already tried hitting the reset button you should first remove the faceplate and check the contacts on the main unit and the back of the faceplate. if they are dirty clean them (with power off) with contact cleaner or a small eraser. if your lucky that will fix the problem but most likely you have a bad ribbon cable. this cable attaches the faceplate contacts to the main unit and flexes as the face tilts. after time these cables get small cracks that may not be visible. you can usualy buy the part from a place like pacparts.com and replace it to solve your problem.
Some one stole my stereo but.....
yes. Ebay for sure or yahoo auctions or check with a company called dealtree (dealadeal.com)
Sep 15, 2008 | Kenwood KDC-MP528 CD Player
Kenwood w6527
ebay is your best bet. simply save a recurring search if you don't find it right away and you will get an email when one is available.
May 16, 2008 | Kenwood KDC-MP528 CD Player
Kenwood kdc 7009 - just bought car w/ stereo in it, but no remote or codes ?
Look for a small hole in the face plate. Take the tip of a pen and try holding it in for a few seconds. Re-setting it should work.....
Jan 26, 2008 | Kenwood KDC-7009
Kenwood KDC-322
If you have the remote control for the unit, or can buy one then you can reset the code. Just ask me how...
Jan 09, 2008 | Kenwood KDC-322 CD Player
Kenwood KDC-MP528 CD Player Logo
145 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
