Question about Oakley Blade OAK0532 Wrist Watch
Make a oakley blade II watch band smaller
I need to know how to make a oakley blade II watch band smaller
  • atul67 Sep 22, 2008
    same watch, cannot adjust strap
5 Suggested Answers
SOURCE: oakley band/strap
I called Oakley customer service and they said mail in watch and they will put on a replacement band for 45 bucks
Posted on Nov 19, 2007
vsndesigns
  • 5 Answers
SOURCE: Aquaswiss Trax watch band adjustment
VSNDESIGNS SAYS:
You should first try to adjust the band at the Clasp first. The clasp has three holes that you could easily move your band up or down into. If you need to remove one or more of the links, try the following.
http://www.fixya.com/support/t315141-adjust_band_aquaswiss_trax_watch
http://www.rgmarchitect.com
Posted on Feb 09, 2008
SOURCE: Band adjustment
I was able to take use a push pin (thumb tack) to get out the (split) pin. I put the thumb tack in the hole of the pin I wanted to remove, place the thumb tack upside down on our counter top and gently but firmly push the pin out. It only has to push out an 1/8 of an inch and then you can pull it the rest of the way. Thanks to the diagram that "guest" posted above - I copied and pasted: http://www.pmwf.com/Watches/WatchSchool/WS%2014%20How%20to%20Resize%20Common%20Bracelets/WS%2014%20How%20to%20Resize%20Bracelets.htm#Split%20pin%20bracelets in the browser and it showed me how the pins work in the wrist band. Didn't need all of the fancy tools. (:
Posted on Mar 18, 2008
escapement
  • 2334 Answers
SOURCE: how do I adjust band on a guess g95290g guess steel mens watch ?
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 16, 2009
SOURCE: How do I adjust my timex wr 30m watch stretch band?
It's very difficult. You have to take the decorative link covering off first, then continue with the actual stretch band by following these directions.
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Posted on Oct 18, 2009
I have a Oakley Blade @ watch that's perfect except the rubber watch band broke and they say its discontinued. How can I fix it?
You may be able to find it on the internet. Once they stop making the parts you have to fend for yourself.
hope this helps. gabe
Oct 20, 2014 | Oakley Blade OAK0532 Wrist Watch
Replacement watch band
You can buy any rubber watch strap and take the loop off for replacement. Just make sure - the strap you buy is exactly the same width as the original ******** your watch. Needless to say: colour should match as well. Rate me, plz.
Mar 30, 2010 | Oakley Watches
My oakley detonator watch strap has split between holes,and also strap buckle.Where in uk can i get a new strap sent out to my home
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 23, 2010 | Oakley Detonator OAK0530 Wrist Watch
I have an Oakley Blade watch with a black rubber band,can it be replaced with a metal one?
If you go to their web site (www.oakley.com/) you will see that the illustration a watch similar to yours (it is a Blade II) and shows a metal one.
If you use the store locator to find one that is near you and speak to them about changing the strap.
Feb 15, 2010 | Oakley GMT OAK0531 Wrist Watch
Changing lens on oakley razor blades glasses
Firstly, remove your nosepiece. Grab hold of the frame at one of the top corners with an index finger and thumb - use your other index finger and thumb to hold the lens, apply presure and gently pull apart. The notch will release. To mount your new lens, insert one notch into the frame and press the other notch into place. Do not apply pressure to the stems or hinge.
Sep 04, 2009 | Oakley Crush OAK0333 Wrist Watch
Oakley judge watch with polished band
I need 2-extra SS band links for a Raymond Weil Tango 5560 Y-044644 watch
Dec 04, 2007 | Watches
Oakley band/strap
Oct 28, 2007 | Oakley Detonator OAK0530 Wrist Watch
Oakley Blade OAK0532 Wrist Watch Logo
456 people viewed this question
Top Oakley Watches Experts
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you an Oakley Watch Expert? Answer questions, earn points and help others
